Results 1 to 7 of 7
    SublimeTime's Avatar
    SublimeTime is offline "Volatile Villian"
    Zex system questions
    I have been running the Zex kit for a couple years now and pretty much have been incident free. That is until yesterday. Went to the track and on the first run, ran out of N2O. No big deal. Change the bottle, fire up the bottle heater, go out for run number 2. Purged fine with a nice white cloud. Come out of the hole, hit the button, nothing. The only thing that happened was that might A/F was at about 9. I assume no N2O, tons of extra fuel. Feels like I am pulling a boat anchor. Unarm, ride it out. Get to the pits and check bottle and pressure is around 13-1400. Could the solenoids have possibly been locked up? I remember Dan mentioning this awhile back but can't recall the end result. Chad and I also checked the system after my last run and now the NMU was not spraying the nitrous. We had to reprogram it. After that, it seemed fine. So my question is this: Will excessive pressure lock up the solenoids in the NMU? Thanks in advance.
    G
    07 Sublime Daytona
    Zex N2O,AFE II CAI,170 t-stat,JBA exhaust,FRI S/S heads,Sparrow cam,Mopar LT's,Ported/Polished Billet Tech 85mm TB, '09 Challenger Getrag LSD.Eagle 09 intake,CTP spacers and driveshaft loop.Custom Edge converter,Paramount Performance flex plate.Install by HEMI31/BFNY Performance.
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    at 1300 psi you froze the solenoid.You gotta keep them under 1100 psi Gary.
    RIP NHDave
    Thanks Erik. I figured it was somehow related to all that extra pressure. I usually keep it at 1100 which hits nicely.
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    I found my Zex never liked to fire above 1000psi. Also One night it wouldnt fire and I had 950 psi. I tapped on the Zex box and it worked. Now I think my problem was at the time was I was not running a in line N20 filter and the noids may have got some rust in there from a bad fill or something.
    The next day I installed a filter and it worked fine for another 6 months.. Hope this helps.
    Quote Originally Posted by 1FST4DR View Post
    Thanks for your input Scott. My system has always been happy at 1100. I agree about the N2O filter.I do not have one. I might be switching out and going with an individual solenoid setup, or wait until the next "mod" and use a direct port setup. Thanks again.
    G
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by SublimeTime View Post
    G
    Either way i would invest in a filter. BTW If you got to a BIG BOY set up you will need a #6 in line filter. Right now you have a number 4. So by a #6 filter with a couple #4 fittings. That filter is about $50-60 so that way you will plan ahead.
    Keep me posted on the switch and if you need any help let me know. BTW Why the switch?
    The switch will be for my new setup which was supposed to be done by now but had to be delayed. Thanks again for your help Scott, and I will keep you posted.
    G
