Results 1 to 15 of 21
    adamwahhab's Avatar
    adamwahhab is offline PPPPSSSSSHHHHHH
    Feb 2008
    FRISCO
    ZEX Nitrous install
    Hey guys i have a question on the zex kit. Im installing a kit on my 300 srt8, which wire do i splice into for the tps ( throttle position sensor) signal.
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Quote Originally Posted by adamwahhab View Post
    Brown w/Orange tracer(stripe)...
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    adamwahhab's Avatar
    Feb 2008
    FRISCO
    How important is it to use the resistor wire they give you in the kit. I bought my kit used, and it didnt come with it, can i use any kind of wire?
    Mar 2008
    dont use the resistor, that is just to make sure you dont throw codes, but it can mess up your use of the kit because those things break. Alot of forum members dont use that thing. I only got a code the very first time i turned the system on, it went away and has never come back.
    adamwahhab's Avatar
    Feb 2008
    FRISCO
    its weird when I turn the system on though, especially while idling, the car will die, It then takes 3 or 4 restarts to finally get the car to idle, but while driving, if I turn it on it seem ok
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    Is your bottle hooked up and open? If not, are your sure the system is not firing at idle and you are not spraying fuel and flooding the car?
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Sounds like its spraying fuel while at idle, not good. Reprogram your box and test your system with the nozzle out of the CAI and into a 2 liter pepsi bottle or something similar. You should make sure everything is functioning properly before running into your motor.
    Mar 2008
    why would it spray fuel and not n2o? Thought the NMU made sure the right mixture was coming in before sending it out, and wouldnt that mean that his TB was programmed wrong to fire at basically 0% open?
    Brooklyn, N.Y.
    It would. I am assuming and hoping the bottle is not open.
    Also, if the system was wired against the TPS sensor at the throttle body it can be a bit erratic with the signal. Many have used the sensor at the gas pedal.
    I also wired in an extra firing button just in case so it won't fire till I say so.
    Mods: Busted 6.1
    Mar 2008
    Quote Originally Posted by bklynmag View Post
    that sounds like a good idea actually. what wire did you but your button inline with? I might do that as well
    Brooklyn, N.Y.
    The one taking the signal from the TPS sensor this way the signal won't reach the NMU to fire unless the button is depressed.
    Mods: Busted 6.1
    Mar 2008
    yea thats what I figured. Just didnt know if a momentary button would have any problems with a back up in voltage at the switch, but if were talkin 5 volts or so it prob isnt a big deal. I may need to do that. So you have to flip the switch, be at WOT, and be holding down the button? or do you have a 2nd toggle switch
    Brooklyn, N.Y.
    Funny you ask, I used to have a momentary I held down but now I have a second button(the one on the bottom below). When I am done spraying I just shut off the main toggle to the system.
    Here's a quick pic:
    Mods: Busted 6.1
    Mar 2008
    Why did you change from a momentary to a toggle? Liked having 2 hands on teh wheel?
    Brooklyn, N.Y.
    Quote Originally Posted by sinistersix View Post
    So I can use the autostick
    Mods: Busted 6.1
