Results 1 to 15 of 15
    BBoyPersia's Avatar
    BBoyPersia is offline eThug cause talkin **** IRL is dangerous
    Aug 2009
    Silver Spring, MD
    Zex kit not spraying?
    If installed correctly, is it supposed to spray if the key is on the on position and manually open the TB? Everything seems to be installed and programmed right, it just doesnt spray.
    bklynmag is offline 7.4 RT
    Brooklyn, N.Y.
    When you turn the key on is the box showing a steady green light?
    5.7 Personal Best: Heads, Cam and Spray - 11.46 w 1.59 60'
    6.1 Personal Best: Forged, Novi 1500 and Spray - 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Aluminum 449 - 10.736 ET , 1.589 60', 125.05 MPH
    rander's Avatar
    rander is offline Just trying to make it in this world
    TX
    you have to program it first. i'm sure others do it differntly, but this is the way i program mine. I flipp the nitrous switch to on with the car on, walk out to the engine bay, press the program button on the ZEX ECU and run like hell to the drivers side and press on the gas. make sure you have your RPM for in park set to around 3000 RPMS. Let it hit the limiter and hold it there. After 10 seconds let go of the gas and turn off the switch. turn it back on and the controller should now be green. When you turn the key off and on it should engage the TB and scare the hell out of your budy up near the front of the car. Don't recommend this last step, but yes it should engage. Did you connect the white wire from the ZEX ECU to the brown and yellow, or is it purple, wire to the TB? Also, anytime you change a tune setting and re-tune the car, you willl have to do the same song and dance again.
    2012 Dodge White Charger
    PB 1/8 run: 7.92 @ 86.92 * 1.76 60' on street tires with DA at 1786
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    yea i programed it manually opening the TB by hand to WOT.
    so your saying instead of manually programming it, hit the program button and hit the gas instead of opening the tb by hand?
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    ok i may have tapped into the wrong TB wire. when we called them to see which wire to tape into they said theres only 1 adjustable voltage wire, i found 2... the one im on is 4.2ish closed and 0ish open. found another line thats opposite, i beleive thats the one i need to be on right?
    Lajus007's Avatar
    Lajus007 is offline LX Padiwan
    Jul 2009
    Hilton Head
    sounds rite to me....that just may be your problem..
    07 Steel Blue...faster than you!...shooting for a 10.0 next time out to the track...
    JimIsland-SRT8's Avatar
    JimIsland-SRT8 is offline make that a 440 please!!
    Aug 2007
    JAMES ISLAND S.C.
    If i remember correctly, the white wire is the one for the pedal.
    Personal Best: coming soon!!
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    well still not spraying. programmed, green light, just wont work! i have a 5.7, dont know if the TB wire colors are the same or not, anyone know which i need to tap into?
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    problem fixed. wasnt enough power from the cig lighter to activate the solenoid. ran a new line from battery and works perfect.
    Lajus007's Avatar
    Jul 2009
    Hilton Head
    wow.....you were running your nmu out of the cigarette lighter.....oh boy....im not even gunna comment on this anymore....
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Quote Originally Posted by BBoyPersia View Post
    From the battery??Why didnt you tap into the power source under the hood next to the fuse box?
    Aug 2007
    JAMES ISLAND S.C.
    Quote Originally Posted by 1FST4DR View Post
    You mean like this!
    AlbertaCharged's Avatar
    AlbertaCharged is offline Destroyer of Tires
    Jan 2009
    Innisfail AB
    Hey JimIsland... where did you get the bracket from for the zex box???? where exactly is it mounted to? Or did you make it yourself?? I'm looking for ideas to relocate my solenoid as the position it's in now is very inaccessable.
    2007 Charger srt-8 zex nitrous with N.O Plate, LMI frankentake, JBA exhaust with magnaflow high flow cats and mids, Predator etc..
    2000 GMC 2500- 6L vortech... pretty much stock
    2007 Kawi Mean streak 1600cc - mod list is stupid
    Thanks to : BMC, Billet Tech, Nitrous Outlet
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    looks cleaner running everything to my dash from inside rather than outside. i didnt do the initial install of all the components either, i just tweaked and moved everything around.
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by AlbertaCharged View Post
    Actually I made the bracket,Its mounted to the coil pack covers..
