Results 1 to 4 of 4
    RARE AIR SRT is offline LX Newbie
    Jun 2008
    Wizards of NOS???
    Has anyone heard anything about this company and their pulsoid technology? There is a company here in town and wants me to get in on a multi system buy. I have never heard anything about them or their systems. I wanted to bring it to the experts before I went any further. Thanks for any info you may have. Here is a little info and a link.
    Highpower Nitrous Systems (manufacturers of The Wizards of NOS) have been working with and manufacturing Nitrous Oxide Systems and other related products for nearly 30 years. As a result, we have developed revolutionary products and systems which are considered to be the best in the world. We are continually developing new innovative designs to bring the nitrous industry to new levels.
    All our systems are manufactured to the highest standards, consequently we are so confident in our products that we offer a lifetime warranty on every product we manufacture.
    The key factor to a Highpower nitrous kit is to deliver "the most dense liquid nitrous possible, to your engine". Starting from the bottle valve and continuing to the injector, Highpower has addressed and developed products from the ground up to make sure nitrous density and efficiency is optimized for best performance, safety, and distribution. This includes several choices of nitrous supply lines to better match flow requirements. A standard -4 braided line flows over 300hp so using it on a 50-100hp application doesn't make sense along with having a fixed length that gets coiled up in many applicatioins as it's to long. Another key factor is the unique jet location situated in the outlet of the solenoid and NOT the injector itself. By doing this the nitrous delivery does not provide that "hard hitting lean-out" that people associate with nitrous kits, while still providing optimal acceleration. A secondary benefit is easier jet changes and fewer jet changes in many if not all applications. Please view our detailed product section, technical section, and message board to learn more about Highpower nitrous systems.
    Features
    Design - We’re the only nitrous company to design the majority of our products (specifically for nitrous use), in-house and have the parts manufactured for our sole distribution. All other nitrous system solenoids on the market are simply re-labeled industrial solenoids and not originally designed from the drawing board up for optimal nitrous delivery and ultimate reliability especially when pulsed.
    Pulsing - Our “Pulsoids” are the only nitrous system solenoids specifically designed and developed for reliable and accurate pulsed control. From the drawing board onwards they were intended for use as a matched pair for optimum results. Our unique jet location at the Pulsoid outlets produces the smoothest power delivery, resulting in less stress on your engine and transmission. Every Pulsoid is hand assembled and tested extensively, unlike other systems that use mass produced solenoids.
    Smooth Control - We offer the only nitrous systems and progressive controllers that were designed and developed to work together in partnership. This results in the smoothest and most even nitrous mixture delivery, helping to eliminate the severe backfires and engine damage associated with nitrous. This unique combination minimizes the stress to your vehicle whilst maximizing performance.
    Mixture & Distribution - Our Crossfire is the only injector designed primarily for single point use, no other injector (nozzle) can give you such an even distribution of mixture across all cylinders from a single injection point. Our Single point systems are the simplest and cheapest of our range but often result in quicker performances than more complex systems (on low power settings). When direct port is essential then the Crossfire is compact enough for the trickiest of installations and in conjunction with our unique combined distribution block, flow correction across the cylinders is rarely required.
    Delivery - Our systems are the only systems with a range of nitrous feed lines to achieve optimum performance at a given power level. Our standard 5mm nylon supply line doesn’t even require a purge kit for day to day use because it's so well matched to applications requiring less than 150bhp of nitrous.
    roman is offline LX Newbie
    Mar 2008
    They are a UK company and have a good reputation over here...........I have mapped a few cars with their kit on with very good results.
    Not sure how the USA operation is set up? but if they just re sell the UK kit you should be OK............
    Here is the web site link as it seems to be missing from your post http://www.noswizard.com/
    Jun 2008
    I posted that from work, not sure why the pasted part doesn't show up.
    from what I read on their forum it looks pretty good. I can't find anything other than their own reports though. What is the benefit of a pulsed solenoid?
    From looking at the videos, I don't see much of a difference.
    Jeff
    MAN WGN's Avatar
    MAN WGN is offline Livin in the worlds biggest Dust Bowl!!
    Jul 2008
    Midland, TX
    Quote Originally Posted by RARE AIR SRT View Post
    Jeff
    It shows up it just in white lettering
