yep...this is from your 13.1 slip
2.578 to a 1.800 = .778
.778 X 1.5 = 1.167
13.193 - 1.167 = 12.026
Odds are you are spinning past the 60' mark, and if you are getting wheel spin on the shifts you are also losing time.
You can play with the RPM activation point and gear lock out if your window switch has it to help with traction.
Thanks, yes, spinning is my issue. I do have a window switch and the prior weekend I had it set for 2nd @ wot. I thought I would try in 1st @ 3500 wot. The ones in the tower said after I ran not to use N20 due to the track is cold and no traction.
2006 SRT Charger,11 second club,P/B 123.00 @11.209
2004 SRT10 Viper Truck, P/B 12.92 @104.89, race weight 5040lbs.
