Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By BlueBee
Thread: TPS programming issue??
    SANTEEN is offline LX Padiwan
    Feb 2009
    Not sure if it's an issue or not. But, I've completed all the wiring and programmed the TPS switch. I've followed the Zex instructions to the letter. When I test the programming, by opening the throttle blade manually, I hear the solenoid engage about a 1/4"-1/2" before the throttle is fully open. When I check the TPS voltage signal, it's engaging about .5 volt before WOT. For example my tps shows WOT at about 4.6. The solenoid clicks on at about 4.1 volts. Is this normal? Okay? Or not? I tried porgramming it several times, just to make double sure that it was right. Thanks as always for your help. Y'all have made this a breeze to install. I came into this scared and misinformed about nitrous. And now I feel much more comfortable about using it.
    2006 300 SRT8
    Z
    EX Nitrous kit w/ Nitrous Oulet plate, Modern Muscle custom grind Nitrous Cam, JLT Carbon Fiber Intake, Predator custom tune from Johan (DIABLOTOONA), Edge 3200 stall convertor, Paramount Valve Body, 6.1 Mopar TCM, SLP Loud mouth II catback, Magnaflow midpipes w/ Highflow cats, 170 tsat, BT catch can
    2007 Grand Cherokee SRT8
    Bwoody intake, Works longtubes, Borla S catback, Custom Johan tune, Mercedes Blue Tops, Eibach springs
    Feb 2009
    Anyone? I know we got some Zex kits out there.
    2006SilverRT is online now LX Guru
    Mar 2010
    Memphis, Tn
    I saw that your using the window switch. Where did you tap the throttle position sensor wire at? It should be brown/white wire. You can tap it at the throttle body but i would suggest behind the pedal to eliminate issues. Im not sure how the window switch works, but on my progressive controller i can go WOT with the car off and look at the screen on the progressive controller and see that it is engaging at WOT. I also had to calibrate it so the controller picked up WOT voltage. Again not sure if this applies to you....just thinking out loud trying to help since no one else has replied yet.
    Motor:
    1.724: 60ft
    7.701: 1/8
    90.22: 1/8 mph
    11.997: 1/4
    114.34: 1/4 mph
    BlueBee's Avatar
    BlueBee is online now Nitrous addict
    Portland Oregon
    Use wire at pedal, it will give erratic signal at TB, we all put it at the pedal....
    1FST4DR likes this.
    426 STROKER 11.5CR built by Ding's. INERTIA STROKER CAM, Paramount Trans/TransBrake/TC/FLEX/DS/8.8 Differential with 4.10 gears, rwhp 758/ 731 rwtq
    PB N/A 10.948 @ 124 w/-200DA
    Nitrous PB 10.19 @ 136 MPH
