Results 1 to 6 of 6
    RDunn's Avatar
    RDunn is offline 8.3@165mph
    Sep 2007
    St.Louis,Mo
    running a big shot,What Plugs?
    right now im running 1 step colder plugs in my 5.7 on a 125 shot.NGK 4306 copper...would be an srt8 heat range.
    i have a 372ci motor in the garage and i just ordered a new kit from nitrous outlet. im going to use a 200 shot out of my new plate kit and run a 75 out of my zex kit.
    what would you guys using the bigger shots use?
    thx
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I'm guessing 1 range colder and gapped to .35 . How about your fuel system? I would think the stock 5.7 pump is not going to keep up. Other things would be some sticky drag radials and probably rear axles. My friend has a 392 with a hot cam, heads and a 150 shot and the General Grabber UHP's 255/55/18's will spin the whole length of the track! With that big a shot, you'll need to either pull timing or run much better fuel. I've had good results using NOS systems racing octane booster, it actually works, 1 bottle to 16 gallons will bring 91 octane up to 97 octane.
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    NGK has 2 plugs that are 1 step colder than the stock 6.1 plugs 2 steps colder than 5.7
    NGK 2315 and NGK 6509 the tech told me that the 6509 may be better for FI and high compression cause it doesn't have a projected tip so it doesn't stick so far into the chamber and has less chance to foul out
    Video
    1FST4DR's Avatar
    Ft Laud.....
    I would ask Dave"Nitro outlet".If i remember correctly you might want to go
    2 steps cooler and close the gap.Let us know what he says..Im also getting ready
    to run a bigger shot.But Im going to use a progressive set up..
    Mar 2008
    do those octane boosters really make any difference in terms of daily driving? I know they help with detonation, but for occasional street use are they worth it?
    Definitely let us know about the plugs, I might be going to a bigger shot soon as well
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by sinistersix View Post
    Take it easy young man.If your looking trouble you may find it.
    The 5.7's can only take so much..
