Results 1 to 6 of 6
    jb4lsu's Avatar
    jb4lsu is offline LX Newbie
    Sep 2011
    Baton Rouge, LA
    RPM and TPS wire taps...
    So I am getting close to having to wire up my FJO nitrous controller and have been reading up on where to tap into these wires, and have have read different things...
    For the TPS, I am seeing the best spot is to take this signal from the gas pedal instead of the throttle body itself. 2nd wire closes to the drivers seat, got it. Right?
    For the RPM signal I see some people using the injectors and some coming off the coil, as well as using cylinders 3, 7 and 8. So what is the one I need to use?
    Any help is appreciated!
    Thanks!
    SKI WAGON's Avatar
    SKI WAGON is offline Must Go Faster!!!!!
    Aug 2009
    Auburn, Maine
    Quote Originally Posted by jb4lsu View Post
    Thanks!
    You are correct with the TPS signal location and I would recommend going from the injector as trying to get the signal from the coil pack did not work for me.
    2006 Jeep GCSRT-8
    Mods:Mopar CAI-SW Long Tube Headers-High flow mid-pipes-Corsa/Mopar Exhaust-Diablo Trinity-Custom Tune
    -FRI Little Boy Camshaft-Mopar TCM-Innovate LC-1
    2006 Dodge Magnum R/T AWD
    -Gone but not forgotten
    jb4lsu's Avatar
    Sep 2011
    Baton Rouge, LA
    Quote Originally Posted by SKI WAGON View Post
    The injector on which cylinder? Either wire works on the injector?
    juiced97mustang is offline LX Newbie
    Apr 2013
    Is that tps wire u speak of falling voltage or rising? I hear we need the falling voltage wire for a smooth voltagr sweep
    Apr 2013
    We have an 06 srt8 300 w the 6.1L and i just gotta wire it now
    Apr 2010
    Hemi 6.1/5.7
    Tach Wire: #7 injector wire - red side of connector OR Blue wire - Green Tracer coming off coil pac * 5.7L go off #3 Coil Pac *
    TPS Wire: Down off of Gas pedal – second wire closest to driver seat – should be a white wire
