Results 1 to 10 of 10
    robsrt's Avatar
    robsrt is online now SpeedRated Motorsports
    Fort Pierce, FL
    Progressive controller
    I'm thinking about going with a progressive controller on my nitrous setup. I've started spraying a 175 shot and traction is now an issue. I would like to launch on the 100 then have the other 75 come on once I get rolling.
    I was wondering if I could do this without going to a two stage setup and just adjust the shot with the controller. Has anybody tried one? If so, could you give a recommendation to which one you liked?
    RIP Lou
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    Rob,I was told that it isnt possable with the Zex kit.The few i looked at stated that in small print.However i really didnt look that hard
    robsrt's Avatar
    Fort Pierce, FL
    I've looked at a couple of them and they said not compatible with the zex kit. I did find a cold fusion one and it didn't have any disclaimers. I was going to research that one a little more. I hoping someone may have used one with the Zex. If not, I may just try a two stage system.
    RIP Lou
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by robsrt View Post
    If that is your plan get in touch with JMATT,He is selling his N20 crap..Nice pricing as well.let me know what you find out about the cold fusion
    RARE AIR SRT is offline LX Newbie
    Jun 2008
    You may want to check out a UK company. They boast huge spray on stock bottom ends by doing it pulsed or progressively. They are Wizards of NOS. I am trying to find out as much about them as possible myself for upcoming Pinks all out at Bandimere in Denver.
    Jeff
    robsrt's Avatar
    Fort Pierce, FL
    Quote Originally Posted by 1FST4DR View Post
    I've already contacted JMatt on the torque converter. I'll probably see what stuff I need for the second stage. I'll shoot him a PM later. I just wanted to be sure that was the route I wanted to go.
    Rare Air,
    Do you know the name of the UK company?
    RIP Lou
    1FST4DR's Avatar
    Ft Laud.....
    Wizard of NOS or something like that rob..
    Ray@NitroDaves is offline Supporting Vendor
    Jan 2008
    Do alot of research on Trevor and the Wizards of NOS before purchasing, not saying he sells bad product, but they do make claims that don't always hold up.
    On the ZEX/Progressive controllers...its not the the progressives aren't compatible with the ZEX kit...its that the ZEX NMU is not able to be progressed.
    A progressive controller works by pulsing the ground signal to the solenoids.....if you connect the progressive control wire to the black wire on the ZEX box you will pulse the ground to the ZEX electronics, and could cause major issues with the NMU.
    Multistage is the only option if you want to keep the ZEX NMU....or replace the NMU with a stand alone set of solenoids and add a progressive that includes a window switch and TPS activation.
    For Sales or Tech support e-mail Ray@nitrodaves.com or call 888-463-2781
    94 Pontiac Formula (The Fast Car) http://www.fquick.com/garages/Pontia...mula/1994/676/
    Nitrous Wiring Diagrams http://www.fquick.com/garages/Smart/Roadster/2000/3821/
    robsrt's Avatar
    Fort Pierce, FL
    Thanks Ray. That's exactly the information I needed. Looks like my best bet would be to add a window switch and a second stage. Looks like I'll be making another purchase from Nitrous Outlet.
    RIP Lou
    JMatt is offline Faster than the fastest 3rd Gen Hemi
    Nov 2005
    Wizard of NOS is full of himself, and full of crap. The REAL racers (hard core Pro Mod drag racers running 5.99 in the 1/4 mile) have examined his claims, and found out most of it is crap.
    His stuff sounds great in theory, but apparently when put to the test, he fails.
