can i put a 2005 silverado nitrous kit on my 300c if so what do i need?
because i cant find were to put the fuel line?
2006 Chrysler 300c mods = K&N CAI, Poweraid tb spacer, FRI sidewinder cam with 6.1 springs and pushrods, Jet t-stat, Predator and SLP power flo mufflers
2003 chevy ext cab silverado Z71 5.3 with full bolt ons
**SOLD**2000 chevy camaro SS 5.7 with livenoise stage 2 heads, TSP MS4 cam, Fast 90/90, Pacesetter LT headers, SLP loudmouth 2 catback, SLP lid, ASP pulley, built trans + Yank 4k stall and HP tuned
oh btw the kit is a harris speed works
What brand kit??Wet or dry???You may need to buy a adapter,Our mopars do not have schrader valves like the GMS do..
its a harris speed works wet kit
Does it work off the TPS senser??Do you have a kit number??
this is the kit
http://www.harrisspeedworks.com/shop...cat=364&page=1
You will need this..
http://www.nitrousexpress.com/Pages/FuelRailAdapt.htm
Or get the adapter from Zex for the Hemi application..
Cant seem to find the part on line but its out there..
You can also mount the micro switch under your gas pedal
or you can get a TPS switch module...
FYI With the NX fitrting you cant fit an engine cover on the 5.7,But with the Zex adapter you can..Hope this helps..
This is the only adapter kit I could find from Zex. Part #82138. I know they offer different adapters but this should get you started.
http://zex.com/Catalog/ZEX101-08/ZEX101-2008_PG24.pdf
'08 BEE #935
is there any kind of fuel rails for the stock 5.7 intake
Check with Lisa or Chris at BMC Performance they will take of you weather its the line kit or the fuel rails.
http://www.bmcspeedshop.com/
'08 BEE #935
make sure you know that the 5.7 needs a bit of trimming to be done in order for these rails to fit. I am going through putting them on right now. Also, dont worry about the front crossover, on the 5.7 the braided line doesnt fit under the throttle body so just get the end caps.
