Results 1 to 15 of 20
    RDunn's Avatar
    RDunn is offline 8.3@165mph
    Sep 2007
    St.Louis,Mo
    nitrous plate rated to?
    what are the nitrous plates rated to....i.e...how big of a shot can you run thru it.
    Mar 2008
    are you talking about the throttle body plate from nitrous outlet? Like the same one me, 1fast4door, and k4000 are running? I believe scott is running a 150 shot through his, but on the chart it goes up to 200
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    ya thats what im talking about.
    200 will work for the first stage....then i will keep the zex on there for a 2nd and spray a 75 shot
    ko4000's Avatar
    ko4000 is offline Blame it on the Alcohol
    Jan 2007
    Fort Lauderdale, FL
    The plate comes with jetting up to 200. I am not sure if it flows more than that.
    AFE CAI, SLP LM II, ZEX 100Shot, Nitrous Oulet Plate , Mopar LT's/cats,
    Inertia Motorsports Perf. Heads & Spartan Cam -Ported 6.1L Oil Pump (Installed by Matt @ Michigan Hemi Performance)
    No-ESP mod, Predator Tuned, TEIN SS Coilovers, 20" Viper Replicas (custom powder coated)
    CMR Tune by Johan @ Diablo Sport
    roswald0511's Avatar
    roswald0511 is offline RIP Clifford
    Where the Wire was filmed
    R Dunn, Contact Nitro Dave at Nitrous Outlet. He can get you an answer.
    Off topic, did you end up testing anything over a 100 shot on the stock bottom end?
    Ray@NitroDaves is offline Supporting Vendor
    Jan 2008
    The plate can flow up to 400HP....
    For Sales or Tech support e-mail Ray@nitrodaves.com or call 888-463-2781
    94 Pontiac Formula (The Fast Car) http://www.fquick.com/garages/Pontia...mula/1994/676/
    Nitrous Wiring Diagrams http://www.fquick.com/garages/Smart/Roadster/2000/3821/
    RandomAccess's Avatar
    Monroe,NY
    Quote Originally Posted by Ray@NitroDaves View Post
    can the -4AN hose keep up with that? I thought beyond 300 shot you have to upgrade the hose.
    12.571 @ 106.71
    1FST4DR's Avatar
    Ft Laud.....
    Good question^^^I know you should at least run 6 from the bottle.I assume you mean from the noids to the plate??
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    Quote Originally Posted by roswald0511 View Post
    running a 125 shot right now...bout 4 bottles so far
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    good to know,im going to run a 200 out of it,then a 75 on the top from the other stage in 3rd gear
    Quote Originally Posted by RDunn View Post
    You know the unwritten rule is after 4 bottles, you have to go to a bigger shot.
    Monroe,NY
    Quote Originally Posted by 1FAST4DR View Post
    Yeah... exactly what I mean... and the other piece is what are the noids rated at as well. I don't think the Zex system goes beyond 150 IIRC
    12.571 @ 106.71
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    yeah, im only going to spray a 75 from the zex. im going to buy another kit with the plate system from nitrous outlet
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    ^^^What he said^^^
    I think you would be fine past 200, the limiting factor would be the rest of the system, which it sounds like you are replacing anyways. I run 125 no problems.
    Mike
    06 Magnum R/T Midnight Blue
    Mar 2008
    Quote Originally Posted by mhigham View Post
    ^^^What he said^^^
    Mike
    So running the 125 you have had no problems with the rear end or anything else on an RT? Hmmmmmm
