Results 1 to 15 of 15
    torRed #1169's Avatar
    torRed #1169 is online now Who has the winning lottery numbers ???
    Nov 2006
    15 minutes from Englishtown
    Nitrous install questions.....
    Ok I have couple questions for the nitrous pros.
    1.How OK is it to put your bottle in the spare tire well sideways like in the pic below.(Or am I better off just putting it on top - I like the fact you can't see it-major plus)Or on the angle-semi sideways???
    2.Zex kit that I have comes with a fuel line disconnect tool.Is it any good to use or should I get one from Autozone ahead of time?
    3.I have a C&L intake witch has a place on it for the nozzle right above the sensor. Is it OK to use that? not too close to TB ? I think it was put there for the nozzle.
    Pictures below.
    Thanks,
    Chris.
    #1 Question :
    #3 question :
    Thanks a lot,
    Chris.
    RIP nhDave - Never forgotten, my friend
    ______________________________________
    11.59 N/A and 11.19 on 100 shot.
    392 with Frank Racing heads and cam.
    Dominator Converter.
    Install by HEMI31.(BNFY Performance)
    Tuned by LAFRAD.
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    Hey Chris,Its hard to tell but the place on the CAI for the nozzle,Is it before or after the AIT?The nozzle needs to be between the AIT and the TB.The bottle mounted sideways will work ok,Its not the ideal position but it will work.You will need to clock
    the tube in the bottle so it will be able to get as much N20 as possIble under acceleration..If the tool they gave you works,Use it..lol Cant hurt to try and save a couple bucks..Hope this helps Scott
    1FST4DR's Avatar
    Ft Laud.....
    Actually i see the AIT in the pick now.If the N20 and fuel does NOT spray over the AIT then that location should be fine..
    bklynmag is online now Maggie under construction
    Brooklyn, N.Y.
    Ditto on the above. Try and mount the bottle front to back if you can swing it.
    Hemidon has a pretty slick set up on the side that didn't compromise too much trunk space in his Charger.
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    You will be fine with the bottle side to side as long as the pickup tube is angled closer to the rear of the car.
    BFNY PERFORMANCE
    RIP My Friend
    Nov 2006
    How about a window switch?
    Pros/cons.
    Tuned by LAFRAD.
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    how big of a shot? For a 100 shot or less you wont really need a window switch but it is safer to have one.
    FlyByU's Avatar
    May 2006
    Long Island, NY
    Oh and the spot on the C&L for the nozzle is pefect. Ive been using that location as of late.
    SublimeTime's Avatar
    SublimeTime is offline "Volatile Villian"
    Good Luck Chris. You have all the right guys answering your ?'s. They all helped me out immensely.
    Gary
    07 Sublime Daytona
    Zex N2O,AFE II CAI,170 t-stat,JBA exhaust,FRI S/S heads,Sparrow cam,Mopar LT's,Ported/Polished Billet Tech 85mm TB, '09 Challenger Getrag LSD.Eagle 09 intake,CTP spacers and driveshaft loop.Custom Edge converter,Paramount Performance flex plate.Install by HEMI31/BFNY Performance.
    Mar 2008
    I have heard of people who mounted the bottle sideways that cannot get the final 2 lbs of n2o out of the bottle, so they end up mounting it forward anyways later. The tool that comes with the zex kit will work, but it sucks and I broke it in 2 seconds, so i went to autozone anyways. Just make sure you are careful with it
    MagnumRT2SRT8 is offline LX Guru
    Feb 2007
    Glendora, NJ
    Aww, Chris, now I'll never be showing you my taillights at Etown! Good luck! Gotta love the power of the haha juice.
    SVT2MagnumRT
    - 2005 Mineral Grey Magnum RT Gone!
    - 2006 BB Charger SRT8 on 20 SM BHP's
    - Diablo Predator
    - no resos, Airhammer
    And 2 Booster seats
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by sinistersix View Post
    If the tool does brake,You will need a 3/8 size tool..
    Nov 2006
    Thanks .
    That is exactly the info I was looking for from everyone.
    I'm sure you're helping others that come after me as well.
    You guys are GOOD.
    Tuned by LAFRAD.
    Nitro Dave is offline Supporting Vendor
    Apr 2008
    When having to mount the bottle side ways the key is to rotate the niple towards the back of the car. The bottles inner pick up tube has a 45 degree bend at the end that matches the direction of the nipple. With the bottle mounted this way when the car launches and the G-force pulls the liquid nitrous to the back side of the bottle the pick up tube will still pull the liquid nitrous. Since the bottle is not mounted Valve forward there may be a small point of use earlier that the pick up tube does not get the liquid nitrous. However I do not think it would be that noticable of a difference.
    Dave
    If you want the highest quality, highest flowing products backed by the most knowledgable staff with full time tech service that answers the phones full time, responds to pms, emails and post on the boards with technical information our products and our company is the choice for you.
    "The Bitterness of Poor Quality Lingers Long After The Sweetness Of Cheap Price Is Forgotten".
    Click Banner to Visit Website
    [/URL]
    Nov 2006
    That is what I was thinking as well .
    I mounted the bottle on a slight angle (still sideways) and rotated the nipple little bit to account for g-force.
    Tuned by LAFRAD.
