Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
    HEMIDON's Avatar
    HEMIDON is offline 426ci Mango
    Oct 2005
    Bowie, MD
    Nitrous Blow Back on a 5.7
    I seem to have found out what happens to a 5.7 intake when the motor is fired up with a manifold full of NITROUS !!!!
    I pulled the intake off tonight !!!!!... I'll get further in it tomorrow night
    The manifold blows out at the seams
    not to mention blowing the gasket out between the EGR tube and the valve, 3 intake runner seals are blown and the Throtle Body seal to the manifold is blown out.
    I hope the motor is not hurt. Its building enough crank case presure that it blows the dipstick out of the tube
    Photos later
    I don't know who to blame
    I went on a cruise last week..... When I got home my car ran like ....???!!
    It had a random misfire code, plus 5 others. The A/F went off the scale lean when I would take my foot off the gas when coasting. At idle
    the A/F would swing from about 12.5 to 15. Cruising the A/F ran in the low 14's
    I left my keys with my 20 year old son
    ... and told my Daughter's 19 year old boyfriend he could drive it 1 day to the shop where he works...
    STUPID ME !!!!
    So at minimum I need an Intake Manifold... Please reply in the WTB Forum
    elcobra44's Avatar
    elcobra44 is offline The times they are a changin...
    Feb 2006
    Batavia, IL
    Argh... Doesn't sound pretty.
    Did ya snap any pics of the carnage?
    HEMIDON's Avatar
    Oct 2005
    Bowie, MD
    I got some pics of the Manifold. I might be able to get them posted tomorrow. Hopefully I'll be able to pull the rockers and do a Cyl leakage test when I get home from work. What concerns me is the intake is full of oil and the crank case pressure blows out the dip stick.
    elcobra44's Avatar
    Feb 2006
    Batavia, IL
    You had a random misfire code.. What were the other codes?
    pimp mobile's Avatar
    pimp mobile is offline PIMPIN' IN SIN CITY
    vegas
    yep. i had a sneeze like this too. blew the bottom off the mani and squashed cai. aslo bent a couple of push rods (later one of them went from bent to broken). good luck.
    06 BB 300c
    FRI milled street racing heads
    FRI littleboy cam
    d'vinci rims, 305/30/22 265/35/22 dunlops, iced license plate frame, iced doorlocks (int), iced clock, srt8 int. door pulls, srt8 rear chin, kw 2, hotchkiss sways, shock tower brace, new front end w/ bentley headlight covers moulded in, rolex emblems,debadged, demolded, leather console, green turn signals, color matched tined tails and markers, bentley grill and vents, cool it, no esp, afe, kooks, diablo, flowmasters, magnaflow res., manny spacer, e85,r1 drilled and slotted rotors, 100 shot of go juice
    Nixon's SRT is offline LX Newbie
    ILL
    What system are you using? Hope you dont have any major damage.
    HEMIDON's Avatar
    Oct 2005
    Bowie, MD
    The system that caused the problem is a NOS Sniper. It had a leaking nitrous valve. I found the problem when I tested the system before I ran at the 1320x event. I had a new valve temporary plumbed in for the event but I reconnected the system to the bad valve for a show the Saturday before I left Sunday. I never expected that my son or my daughters boyfriend would open up the bottle.
    At least the leak was on the first stage with a .040 jet, not the 062 I have in the 2nd stage
    I kind a believe my son when he says he did'nt do it. I don't know about my daughters boyfriend. He hasn't spoken to me since I got upset about the car having been 900 miles on the trip meter and the tires set at 32" not 28.5". Also the car was dirty, the front wheels were gray from brake dust and rubber was slung up in the rear wheel wells. To make maters even more evedent my drag tires were super clean and the rear lugs were so tight I had to use a cheater bar to get them off
    STUPID ME
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Don if your building pressure in the crankcase a compression check would probably tell you what you need to know at this point........I would pull the PCV valve first though........the sneeze probaly locked it closed and thats why your getting all the crankcase pressure.
    BFNY PERFORMANCE
    RIP My Friend
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    Damn, not sure what is worse, the mechanical breakage or the trust issues with your daughter and her boyfriend...crap. Sorry Don - hopefully this ends up being an easier fix than expected.
    If you want a 6.1 Intake Manifold - FlyByU is selling one. PM dan and see if this is an option still.
    rander's Avatar
    rander is offline Just trying to make it in this world
    TX
    Yeah, i heard that a FRI car with a sidewinder and 6.1 intake with stock heads did pretty well on the dyno. If it's the same dyno i dyno'd before in Houston, the numbers are realisticly comparable, since my numbers there were close to the same numbers here in my hometown. Of course there is a bunch of cold weather going around so...
    Mine: 2012 Dodge White Charger SRT8 6.4
    Wife: 2012 Jeep GC Overland with Hemi
    Sold: Black 2012 Dodge Challenger SRT8
    Sold: Silver 2008 Jeep Grand Cherokee SRT
    Sold: 2006 Dodge Charger Daytona modded
    04hemipwr's Avatar
    04hemipwr is offline From Hemis to turbines...
    Grand Rapids, MI
    sorry to hear don.. i bet the daughters bf is to blame!
    i will be more than happy to come over and kick some ass!
    either way i hope you can find the fix and hopefully its something simple.. like erik said check the pcv it could be a easy fix...
    good luck
    CplDaugherty's Avatar
    CplDaugherty is offline Once a Corporal... Still a MARINE.
    Dec 2006
    Back in Indiana
    Ugh sorry to hear about it Don. Sounds like you've figured out who's to blame... it's amazing what little respect some people have for things that don't belong to them. I'd sit down and have a little talk with him.
    Let us know what you find out about the motor... I hope Erik's right and it's just a stuck PCV.
    If you can read this, thank a Teacher.
    If you can read this in English, thank a MARINE.
    Sponsored by Billet Technology
    Powered by Franks Racing Inc
    New build: 392 stroker, FRI street/strip heads, FRI cam, Kooks Longtubes, PI 3400 TC, SLP LM2 catback, LMI CAI, 09 Intake, CTP port matched spacers and DS loop, MTCM, Ported TB, BCR Coilovers, R1 rotors, Autometer AFR and fuel pressure gauge, Motorad 176* tstat, SRT wheels, carputer.
    [06 300C - 70 Mach1 347 stroker - 77 F250 460 - 85 Ramcharger 318]
    "I spent a lot of my money on booze, women and fast cars. The rest I just squandered."
    CHARGERTREV's Avatar
    CHARGERTREV is offline Official 2 Million Poster!
    Jul 2008
    THE KING OF DE
    Hes 19....and you leave him with a bottle? You know he used it....showing off to his friends. I dont think your boy would have because odds are he knows how to use your bottle.....
    2007 BB Charger - SOLD
    2012 Black Mustang 5.0 6 speed - Current
    BigHemi06's Avatar
    BigHemi06 is offline Race It????.....NO NO NO It's A Show Car
    West Palm Beach, FL
    Wow that sucks...post up some pics when you get the chance
    Mods: 6.1 motor with PPP Ported Heads and 224/228 598/578 113LSA, stock tq converter, stock SRT headers with gutted cats, JBA 3in exhaust, LMI hammer design intake. The only 6.1 motor running a 2.82 rear.....Soon to be 3.06 gears.....Installs done by Afterhours Mopar Performance
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    Don. Damn this stinks. That boyfriend has some pair. At that age I would have been really happy just getting to drive your ride let alone abuse it like that.
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
