Results 1 to 9 of 9
Thread: HELP tps wire
    5Litre Eater's Avatar
    5Litre Eater is offline formerly badazz
    Jun 2009
    lanlgey b.c.
    Exclamation HELP tps wire
    ok which wire is it im at the throttle body i dont have a volt meter does anyone know what wire im hookin the zex kit up to?????? keep in mind its a 2006 6.1L
    12.73 @ 110mph na 12.35 @ 112mph on the juice
    MOPAR OR NO CAR!
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Well I like to use the wire at the gas pedal.Here is a couple pics for you..
    BTW That wire is the second closest wire from the driver seat. Hope this helps..
    BTW I have these posted here already,search is your friend
    damageinc's Avatar
    damageinc is offline LX Padiwan
    Northern Va
    damn Scott....they not paying you enough for a good camera yet my friend?
    ^^^mods click here^^^
    HEMI REGISTRY # 874
    PROCHARGED HEMI 5.7
    fast mag's Avatar
    fast mag is offline LX Newbie
    Jul 2009
    winchester VA
    Dont no if its the same as the 5.7 but I used the brown with orange stripe at the throttle body. ZEX has a install video on there web site if it helps ya
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by damageinc View Post
    lol,Actually these were taken at 1 am trying squeeze my fat a$$ underneath the dash board.
    Quote Originally Posted by fast mag View Post
    I know this way you wont have to use that stupid resistor
    Jun 2009
    lanlgey b.c.
    yea i already have the box mounted very hidden and was goin to go off the throttle body i have no idea if its the same colour as the 5.7 does anyone know what colour the tps wire on the 6.1l throttle body thanks for the pics would have helped alot if i was mounting it inside the cabin
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by 5Litre Eater View Post
    Inside the cabin???? Just run the wire inside the cabin,Not the whole box It will take you 15 minutes tops..But to ea there own Good luck..
    1FST4DR's Avatar
    Ft Laud.....
    J Field's Avatar
    J Field is offline She's Now Bottle Fed!!!
    Sep 2007
    Coquitlam B.C.
    yup same wire Brown w/orange stripe
    Personal best 11.82@114mph
    Jet 180 Thermostat, Nitrous Outlet Perimeter Plate, AirRaid CAI W/Scoop, CMR tuned, PT 2800 stall Converter, ZEX Complete Nitrous Kit, Stage 2 268H-13 Comp Cam, Iridium 2 Heat Range Colder Plug, Custom Built Dual Flowmaster Exhaust, Hedman long tube headers & Cat's Deleted, Line lock, AEM Wideband, Autometer Nitrous & Fuel Gauges, Glow Shift Triple Guage Pillar
