Fuel tapping options
Im looking for any way to tap the fuel line and turn it into a normal 3/8 size line, threaded like a port normally used to check fuel pressure, i have a cold fusion kit for an ls1 and all seems like it would work great besides that. any help would be great, thanks.
if i were to purchase this what fitting would i need to go with it? and where can i find it?
3/8 fuel disconnect tool.$6.00 any auto part store
ive got the disconnect tool already, just would need the fitting that screws in and converts to 3/8 like where you would hook a fuel pressure gauge.
i believe the side fuel port is 1/8" pipe.
- You may not post replies
- You may not edit your posts
Forum Rules
