I am getting down to the final few steps on my Zex install and have some specific questions. I have the Pressure On Demand (POD) that turns on bottle heater and remote opener. I have the control unit mounted in the spare tire area next to the bottle. I have to attach 1 wire to a switched connection. What does everyone recommend? Connect it to a fuse in the fuse box or somewhere else? which fuse # also.The handheld controller I want to locate in the center console. How do I get the wire from trunk to console. I found out the the console has a false bottom that pulls out and there is a hole that I can use to run a wire there. I am going to put my arming switch, purge button and POD programmer all in the center console. I can use the help on these last steps though. Want to finish this week.![]()
