Results 1 to 14 of 14
    RDunn's Avatar
    RDunn is offline 8.3@165mph
    Sep 2007
    St.Louis,Mo
    degree's of timing
    what are you guys pulling for timing? right now im running the 91 canned tune with 6 degrees pulled out.i figured since the zex kit says to pull 4 with the 125 shot (but this is for a stock tune) so figured i would pull 6 since the canned tune adds extra timing.
    or do you think its fine to just run with only 4 pulled?
    Lil Hemi's Avatar
    Lil Hemi is offline If it aint a shakin' its just a fakin'
    Feb 2008
    Walnut Grove, Al.
    Quote Originally Posted by RDunn View Post
    To be safe I would stick with the 6 degree pull. This will depend a lot on what octane fuel you are using. If you can't get a dyno tune for the n20 at least use your Predator to check for short and long term knock retard next time you make a few passes with the nitrous.
    '08 BEE #935
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    ive already been on a dyno, no knock. and the zex pills run really fat on the top end of the gear
    lou1355's Avatar
    lou1355 is offline Hoosier Daddy - Finder of Weak Links
    May 2006
    South Florida
    Just to give you guys an idea of the possibilities....
    At the shindig I was running 21 degrees of advance at WOT with a 300 shot.
    The thing was way rich though....8.8 AFR at WOT with the shot. I've got some tweaking to do.
    I do have a built motor with internals picked for nitrous use, so that helps.
    Also, I run 102 in the main tank and 116 in the aux tank for my direct port system, so I don't pull any timing from my street tune at WOT for the track.
    When/if my motor goes BOOM, I'll update you guys.
    Lou
    robsrt's Avatar
    robsrt is online now SpeedRated Motorsports
    Fort Pierce, FL
    I pull 3 degrees on the 125 shot and had no knock. I'm running a 175 shot with 6 degrees pulled. I made one pass on the 175 with 4 degrees pulled and had my best MPH of that night, but I didn't log the run. Like you said, the zex pills are really rich. I would think 4 degrees would be fine with the 125 shot.
    RIP Lou
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    well, my new stroker will be here in a week and im going to be bumping the shot up anyway.
    im going to run a 200 nx system for the first stage and a 75 thru the zex for the 2nd stage.
    lou1355's Avatar
    May 2006
    South Florida
    ^^^^You'll be all smiles, amigo!
    wishing for hemi's Avatar
    wishing for hemi is offline power hungry
    Aug 2007
    back in the 7 cities. beach or bust
    before i got my preditor i ran 2 passes with a 125 shot. no timming pulled. unfortunatly no data log but no boom either remember the 6 degrees is what zex recomends. but if you have a custom tune and you are dyno tested with the juice. you can get away with a little less retard
    predator cmr tune, #1 v1 cams by inertia, 3000 stall by inertia, zex 125hp kit by hhp, stock srt cat back, 22" liquid metal turbines aar strips, racing stripes, front and rear mopower spoilers, steady growng collection of bt front badge door sills. honey comb grill.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    I used to run 100-125 with no timing pull.....just add 100 octane fuel for the track.......if your going to run 93 octane pull 2*.
    BFNY PERFORMANCE
    RIP My Friend
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    i run 93 now for the 125. now are you saying 2* with the 91 tune installed or 2* from stock?
    Aug 2007
    it all depends on the car. i was at a dyno and a guy with very small mods(intake headers exhaust) and a diablo. he had knock noone else there was at all. what i was trying to say before is go to a dyno or at least datalog if nothing else. do it in small increments. if you are pulling 6 degrees data log and if all is good go to 5 and so on untill you start to show knock. once you are showing knock back it off a degree.
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I have had good results with the canned tune 91 octane. I just put in some NOS octane boost, but some 100 octane unleaded would be good insurance if you can't find the booster. Not all octane boosters are the same, either.
    Heavy H.P.'s Avatar
    Heavy H.P. is offline NO LONGER A LX OWNER
    Jun 2006
    ST.LOUIS
    Are u going to have that 370 in a ready for Monster Mopar?
    ^^^Gone
    RDunn's Avatar
    Sep 2007
    St.Louis,Mo
    Quote Originally Posted by formerice View Post
    lol nos octane booster...you know that stuff actually LOWERS you octane rating right....DONT put that stuff in your car. or ANY supposed octane booster in,cept maybe torco.
