Results 1 to 2 of 2
    MuscleMan305's Avatar
    MuscleMan305 is offline Hopped up on Super Supreme
    South Florida
    Air/Fuel Ratio Lean Shut-Down Switch ??
    http://www.dynotunenitrous.com/store...p?idproduct=67
    Does this thing work for our cars?? Im about to order it.
    For those that know alot about nitrous: I ordered the nitous outlet throttle kit and want to add as much insurance to my motor as possible. Is this the best and cheapest way to do it? If my fuel solenoid fails, Nitrous pressure drops or anything will it cut off the n20 flow? As bad as i want an excuse to grenade my motor and upgrade to a stroker, i cant afford to at this moment as this is my daily driver and i had to scrape pennies as it is to afford this nos kit. Please any suggestions would be extremley welcomed and appreciated.
    Ray@NitroDaves is offline Supporting Vendor
    Jan 2008
    I would not suggest relying on that part if you are not adding a stand alone wideband O2 sensor to the car. The OEM narrow band sensors are not accurate enough to depend on for security.
    The design works fine as long as you can supply it with dependable data.
    For Sales or Tech support e-mail Ray@nitrodaves.com or call 888-463-2781
    94 Pontiac Formula (The Fast Car) http://www.fquick.com/garages/Pontia...mula/1994/676/
    Nitrous Wiring Diagrams http://www.fquick.com/garages/Smart/Roadster/2000/3821/
