I'm hoping to use the fuel rail tap below for nitrous and a fuel pressure gauge sending unit. Seems like it might be a little tall for the fuel line to reach, but not sure. Anyone use this?
I know I have to pull a fuse for the fuel pump and run the car out of gas first. Is there a special tool I need to get to remove the connection from the fuel rail?
It looks like the threaded nipple and plug are sealed with Loctite. I just tried removing the plug and it won't budge, feel like it wants to strip. Any ideas on how to get it out? And if I do get it out, what do I want to use on the threads of the f/p sending unit threads?
Appreciate any help.
Thanks
Arrington Forged 6.1..ported 5.7 Eagles..HHP Ported Intake
227/235 cam..Paramount Trans..Dominator..RPM Roll Bar
Nitrous Outlet..DSS driveshaft..CTP DSL..'09 Getrag 3.06
Kooks..Corsa..LMI 4"..ATI 13% UD pulley..Billet Tech..BFNY
11.65@117.3 w/1.61 60' NA--10.68@126.23 w/1.51 60' N20
I used the exact same set up for my f/p on my supercharger set up. That nipple is a son of a gun to get out....but it will come....we used a vise and elbow grease to budge it. We used thread tape on the sending unit for install. Good luck!
^^^mods click here^^^
HEMI REGISTRY # 874
PROCHARGED HEMI 5.7
I use the same part on my NOS setup. The hose will reach but it will take a little finess.
09 Plymouth SRT8/6SPD - CAI, Predator, 180, Reso Delete, Hurst Shifter, SLP Line-Lock, Sequential Taillights, Autometer Shift light, Metco driveshaft loop, Valentine One, AFCO coilovers, Arrington 85mm TB w/NOS, Nitrous Express, SLP line-lock, Poly motor mounts, Pedders Front Bushings, Pedders Rear Cradle Bushings, Razor's Edge Froont and Rear Strut Braces, Chubby Pro sway bars. 12.369/110.51 MPH in 1/4, 1.724 sixty foot time.
Yea autozone,napa all your local parts stores should have the tool you need. No mine came that way new with the locktite
Yeah bud,That 3/8 fuel disconnect tool is about 6 bucks. And its the locktite screwing with ya,Why they do that I dont know,But some heat wont hurt it.Just remember its not a pizza![]()
Yeah, it was a bitch to get out. I secured the allen wrench in the vise and held the adapter to avoid mangling it up in the vise. Took a little muscle, but it popped loose... I used teflon paste on the threads. I prefer it over the tape...
2008 Charger SRT8 (8.26 @ 85.45) - (12.95 @ 108.90)
Scott, your tip worked. We whispered a little heat over it with a mini butane torch, and the plug finally let loose. Thank you
Now, the threads for the f/p sender. Teflon paste, tape, red or blue loctite? Looks like it was red loctite on the plug and nipple.
What say the experts?
Thanks for all the advice![]()
Tape or teflon will be fine.
