Results 1 to 7 of 7
    Neal@nitrousoutlet is offline Supporting Vendor
    Mar 2012
    16 Nozzles, 4 Rails, Tons of Fun!!!
    So the mad scientists in the back are at it again. A dual nozzle L92 Edelbrock Victor Jr. intake with 4 rails will definitely get you moving! Some serious machine work goes into a project like this to get everything set up the right way. To properly get those nozzles placed correctly we had to machine off the original fuel rail mounting pads so that the second set of nozzles could be placed. Taking the original mounting spots off the intake meant that we had to come up with a mounting solution for the fuel rails. This is where we had the spacers cut on the lathe and make custom mounting brackets for the fuel rail. The intake was drilled and tapped to accept the spacers and bolts on the intake plenum. Voila the fuel rails are mounted just as solid as they were originally intended.
    Now that the 16 nozzles are mounted and the fuel rails in place we can move onto the fun part, plumbing the 4 rails and 16 nozzles. This system will be capable for up to 800 hp per stage.
    Here you can see the stock intake before machine work. Note the mounting pads for the fuel rails on the outside runners.
    Here is the machine work after taking the fuel rail mounting pads off the intake.
    Here are the photos of the nozzles placed in the intake. The guys in the back are hard at work right now starting the plumbing and rail mounting so stay tuned to see the progress on this intake.
    Neal Jimenez | Nitrous Outlet
    Neal@NitrousOutlet.com
    Nitrousoutlet.com
    (866) 648-7637
    "Like" Us on Facebook
    Nov 2008
    Albany, IL
    That's pretty sweet. Like a work of art.
    Sjohalsrt8's Avatar
    Sjohalsrt8 is offline LX Guru
    Sep 2011
    WORLDWIDE
    HOLY MAN!!!!!!! That's some serious stuff rite there
    Mar 2012
    So today they got all of the rails drilled, tapped, and ready for the plumbing. Nothing that looks magically creative but takes some time to do since they are having to drill and tap 10 holes in each rail coming to 40 drilled and tapped holes in total! Some plumbing might start before the end of the day.
    Mar 2012
    Plumbing is started!!! You can start to see where this project is going.
    ONE LOVE's Avatar
    ONE LOVE is online now LX Guru
    Jan 2009
    The Beach- Orange County , California
    Wow!!! Amazing
    First day out on the old set up.... @ Fontana,CA
    10.89 @ 127 w/ 1.61 60'
    HUGE Thanks to: Cam @ Crank This Performance..... Adam @ ST Motorsports..... Peter @ Forgestar Wheels..... Whiteline Suspension...... Arrington Engines..... & Iconography Studios
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    2 stage direct port, epic!!!!!!
    9.18 @ 150 mph
