Results 1 to 13 of 13
Thread: 12volt Source
    Heavy H.P.'s Avatar
    Heavy H.P. is offline NO LONGER A LX OWNER
    Jun 2006
    ST.LOUIS
    12volt Source
    Im wanting to know where you guys have your 12v Source hooked up to for your kits.
    ^^^Gone
    J Field's Avatar
    J Field is offline She's Now Bottle Fed!!!
    Sep 2007
    Coquitlam B.C.
    I have mine run seprately from the battery with a disconnect switch up front, FYI all of my system Is run through relays.
    Personal best 11.82@114mph
    Jet 180 Thermostat, Nitrous Outlet Perimeter Plate, AirRaid CAI W/Scoop, CMR tuned, PT 2800 stall Converter, ZEX Complete Nitrous Kit, Stage 2 268H-13 Comp Cam, Iridium 2 Heat Range Colder Plug, Custom Built Dual Flowmaster Exhaust, Hedman long tube headers & Cat's Deleted, Line lock, AEM Wideband, Autometer Nitrous & Fuel Gauges, Glow Shift Triple Guage Pillar
    Mar 2008
    ignition from under the steering column, or you can get it from accessory at the key or behind the radio
    Grant@nitrodaves's Avatar
    Grant@nitrodaves is offline Supporting Vendor
    May 2009
    Texas
    For "KEY ON POWER" nearly every vehicles under dash fuse block will have an Acc. pin or Ign. pin that has 12v with key on ACC. and RUN.
    That circuit isnt meant to provide large amounts of power either, just small amounts like to your arm switch then to relay activation pins like 85 or 86 ONLY.
    If your looking for power to solenoids or heater etc, I run 1 or 2 large(10-12ga) wires from battery to a small aftermarket fuse block and run main power from there to solenoids etc. An extra fuse block helps for diagnosis too. Im would hope most auto parts stores will have a fuse block. Makes for a clean install too.
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    If your looking for 12 voltsa under the hood you can use the power terminal near the fuse box as well.
    Mar 2008
    Quote Originally Posted by 1FST4DR View Post
    yea but using a constant 12v source is a pain and can be dangerous if using it for a heater or something like that because you can forget and leave your stuff on after the car is turned off
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Do a search of Plcman's threads. He has alot of power solutions for switched power.
    Heavy H.P.'s Avatar
    Jun 2006
    ST.LOUIS
    Hey everybody is this something I should read up on or let my installer worry about it.
    How do some of you have yours setup?
    Hey Grant ill look into those blocks.
    J Field's Avatar
    Sep 2007
    Coquitlam B.C.
    There is also an acc wire in the main harness in the trunk, when you lift up the plastic trunk cover you will find the main harness heading to the battery and fuse box in the spare tire well, in this harness is a solid pink wire (12 gauge) this will be acc, this is what I used
    AlbertaCharged's Avatar
    AlbertaCharged is offline Destroyer of Tires
    Jan 2009
    Innisfail AB
    What size of a relay is everyone using for underhood? I know the heater relay is a 12 V 40/60 A relay.... but I can't find any that size at any of the local stores for the setup I want to run in the front with my windows switch and nmu.
    2007 Charger srt-8 zex nitrous with N.O Plate, LMI frankentake, JBA exhaust with magnaflow high flow cats and mids, Predator etc..
    2000 GMC 2500- 6L vortech... pretty much stock
    2007 Kawi Mean streak 1600cc - mod list is stupid
    Thanks to : BMC, Billet Tech, Nitrous Outlet
    May 2009
    Texas
    If you have a Nitrous Outlet heater, they require 20-24 amps depending on input voltage. So a 30 amp relay should be sufficient.
    Heavy H.P.'s Avatar
    Jun 2006
    ST.LOUIS
    Hell i'll admit it, i dont know what the hell you guys are talking about. lol
    But I am taking it all in. Thanks for the help.
    May 2009
    Texas
    Let us know what you need more info on and im sure we can get you on board.
