Did you run your KB Boost-a-pump wires outside the car? Underneath the car? That is how the manual tells you to run them. Maybe you pinched/cut a wire when you jacked it up.
Rick
2009 Challenger SRT, Automatic, Hemi Orange
Kenne Bell Supercharger, 2.8 LC
lol I wish
naw its the stocker
naw I left it in the driveway and took the Chally to the track... to watch..lol
Ill check this out tomorrow, im off
Nooo I ran them all in the car..
2010 Charger SRT: Kenne Bell 2.8LC, SLP LM1s PB 11.88@118
HEMI Registry #1522 http://www.lxforums.com/board/f76/6-1l-hemi-registry-1522-mclarengts-257554/
2010 Challenger SRT: SLP LM1s
2007 SRT: SOLD #1447 http://www.lxforums.com/board/f76/6-1l-hemi-registry-1447-mclarengts-238320/
HORSEPOWER IS A LIFESTYLE !!
check the fuel pump relay and fuse...but that is how most fuel pump die> just all as a shudden
So I checked all fuses and they are all good
How do you get this cap off? It looks like it spins off, but how I can't budge it....
need the tool to remove the ring.....or use a bronze drift and a mallet. I would use a volt meter first and check for 12v at the plug. Might just be your BAP died.
RIP NHDave
Did you try changing the tires back?![]()
Sent from my DROID BIONIC using Tapatalk
GTP Stage 2 Heads
Sparrow Cam
Custom Johan Tune
Full 6.1 Exhaust
Catch Can
180 T-stat
Eibach Pro Kit
AAC Rear Wing
2006 Stone White MRT
Tired of dull silver instrument bezels?
all mods -----> 5.7L Hemi Registry # 00495
Several BAP's have died, but mostly the first gen MSD ones. The KB ones and the newer MSD ones are much better, but still die.
Quick way to test is to remove the fuse to the BAP, then just jumper the signal and return wires together. This is the equivalent of putting the wire that was cut at the pump back together and the pump would run off the normal vehicle fuel circuit and not the BAP (boosted) circuit.
Anyone have a write up or pic of what need to be done to drop the Walbro 255 in the stock basket?
ok guys so I checked at the connector on Im getting 11.55volts so I would say thats good... the actual pins to test are 1,2,3. pin 2 is black so I guessed thats ground. when I tested pin 1 and 2 I got 11.55, and when I tested pin 2 and 3 I got 11.55. thats all with the igniton ON. While testing I had my wife turn the ignition off, and it went to 0, then when she turned the ignition back on, it jumped to 11.55. So Im ordering a pump monday.. Walbro 255
Definitely getting voltage. You can get the locking ring off with a screw driver and a hammer but its a pain in the arse. Just don't go poking holes in the tank with the screw driver. Also have less than a 1/4 tank of gas before of it will spill out.
As far as the walbro I have no idea how replace the stock pump with it unless you use a whole new fuel hat with slots for multiple pumps to ensure you don't run out of pressure. Even if you don't run a return line it would still be worth it if you got the coin.
06 MSRT8: HHP Stage 2 Cam, SP Stage 2 Heads, 2800 Protorque Converter, Stage 2 Indy Ported Intake Manifold, Arrington 90mm Throttle body, Kooks Long Tube Headers, Custom Catback, AFE stage 2 CAI, Mopar TCM, BT Catch Can. SOLD
