Results 1 to 13 of 13
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    Water/Meth results
    Well today I went by 383 Hemis house and we got my water/meth kit working......
    It's was a hot mid 90* day here in VA and my IAT was 143 when I went WOT for approx 2 seconds... I was watchin my IAT guage and saw it drop to 74* instantly (less than 1sec.) while my car was still reading 80* from the w/m it hit the peddel again and broke it lose and the car didn't feel sluggish at all..... I'm thinking that b/c of the IAT temps the car wasn't pulling timing so it actually was faster vs the first time I hit it.
    I did notice that the temp rise back up fairly quick (w/in a few mins) I also noticed that the w/m kit only sprays when it's in drive. I tried to get it to spray when I was in park and in netrual and neither worked. I suppose I can just do a 2 sec burn out on the track to get the temp down.
    I have a tune thats for this kit and a on/off switch as well....
    Wanted to mention REDFOX Racing for the kit and the great customer service.
    JAson
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Why did it rise back up quickly did you let of the throttle
    Video
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Glad you got everything working ...Now good have fun...
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    Jan 2007
    Quote Originally Posted by InferAl View Post
    yes AL, when I got out of it and continued to watch the guage it progressively got hotter
    Jan 2007
    Quote Originally Posted by Ghostface Mag View Post
    mee too... Derrick does ur meth spray when ur in P or N and u rev it?
    Jun 2005
    Quote Originally Posted by USCG Charger View Post
    Yup...Remember when we were trying test it up at HHP..If it was running that day up there Meth should have sprayed out the hose I disconnected from the solenoid...
    Jan 2007
    well for what ever reason my kit doesnt work in
    p or N... it only sprays when in gear!
    383HEMI's Avatar
    383HEMI is offline 11's are Imminent
    Sep 2007
    Virginia Beach
    PH
    422 RWHP 432 RWTQ 1.61 60' (1/8 7.70 @ 86.5) (1/4 12.25 @ 106.9) VMP Dec 1, 2007
    now SCTTuned by Hemifever
    First Ever N/A 5.7 Hemi Ram in the 12s (April 21, 2007 MIR)
    Wifey's Car: 2008 Road & Track R/T Fully Loaded
    Jan 2007
    any one have any thoughts on why it wont spray unless it's in D?
    Redfox0099's Avatar
    North Charleston, SC
    [QUOTE=USCG Charger;1701744]any one have any thoughts on why it wont spray unless it's in D?[/QUOTE. ]
    Coastie if the controller is made to come On at a certain RPM and a vacuum setting that can only be reached while the car is under load HOW do you expect it to come on when not in drive?
    Jan 2007
    [quote=Redfox0099;1701790]
    wanna be Coastie... I was under the impresson that I could just rev it past the "certain" rpm range and it kicks on. So let me ask u this. Why was it the other day when I was aski u about it u told me how to set it then asked me to rev the rpms to what ever I set it at and the pump should kick on....
    I have the controller set at 2 and at 12... does that make a difference?
    Redfox0099's Avatar
    doing a burnout in D will meet the requirements to turn the controller on
    Redfox0099's Avatar
    I will keep this short since I am driving home.... You can see the pump activate in P or N as you wi meet the initial requirements of RPM and vacuum to start the pump at 10% but to get it the mist at any signifant volume you would need to produce more load (a lower numerical vacuum reached) to make the pump mist enough to make a difference.... Plus if you mist too much at idle or at lower RPM then you will bog the motor.
