Well after a few hiccups getting my Water/Meth Kit to work I was able to finally see the results at the track.
I do not have any of the gauges and displays that many of you all serious dragsters have so I am relying on my EVIC Engine Temp display and my little activation light to tell me. The temperature at the start of racing was 87.8 degrees and 53% humidity and at the completion of racing it had risen a few degrees to 89.2 and 43 % humidity. It felt alot hotter down at the track.
During the burnouts I watched as the engine temperture dropped 1 degree as it was spraying. At the time it was 180 -179 degrees then it continued to climb to 190 by the time I had set the second yellow stagging light. At that point I had to concentrate on the tree.
The final proof for me that it was working was during all of my runs I had consistant times and ET speed. I started off with an 12.1 @ 118 with my first run and then had consective runs in the 11s @118-119. Being they were consistant I set my dial in at 11.98. All during the elimination rounds I stayed around those times and speeds. My last run which I won my bracket was 12.0 @ 118. During my earlier summer runs my usual ET speeds drops have been drastic as heat soak sets in.
So far this W/M kit may be quite a useful application even for those of us that are N/A.
I love watching my temps drop espaically in auto-stick...
