Originally Posted by
Creative Induction Systems
A supercharger is rpm based so generally the boost comes on higher in the rpm range. A turbo on the other hand is load based, so the point boost comes in is variable. As I have mentioned before, I could easily drive at 33% pedal position and be in 2-3 psi boost. For an SC, the WOT threshold can be lowered to more closely aproximate where boost comes on. However, as you lower the WOT threshold, your pedal becomes more sensitive to movement as the effective range of movement before WOT is less.
When you hear someone say that the vehicle takes off as soon as they touch the pedal or in light load situations, this is what is taking place. It is a balancing act between too little and too much. There are some who do a very good job balancing that line, but it takes specific tuning for the vehicle, not a canned tune as there are too many variables in play.
In particular on a turbo, you can not lower the threshold low enough to cover the entire boost range since load is the driving factor. Possibly with an SC if the rpm based boost point is high enough.
Yes as I have stated, I am aware that some have mentioned that the boost tables are present in the PCM. But you have to keep in mind, that they are not in use, and the physical architecture in the PCM is not configured for them (pin outs and external leads to the required sensors and components). The PCM is the handicap, not the tuning software. That needs to be understood. Also, the PCM program is not being rewritten, but the variables in the tables are being changed. You are still limited by what can actually be changed.
A good example once again is the SRT-4 PCM which is designed for boost. Not only does it have the tables present and in use, but the PCM is also using the MAP sensor to read manifold pressure, a solenoid to switch the MAP sesnor to read to atmosphere for updating barometric pressure reading (at times even when in boost, a TIP sensor (Throttle Inlet Pressure) upstream of the throttle plate to compare to the MAP sensor reading, and two more solenoids associated with the factory BOV and wastegate so it can limit power based on other parameters programmed into the PCM such as vehicle speed, ESP feedback, environmental conditions, etc. And yes it has the ability to bleed boost or bleed exhaust gas through the wastegate to control power output. But, because of all of this, the PCM can detect presure in the manifold at any point, and therefore apply fuel correction throughout the boost range.
None of these components exist nor do the physical pinouts in an LX vehicle so they can not be added to make the boost tables function as intended.
If you can ease into boost below the WOT threshold, you will still be in Closed Loop mode and the AFR will stay in the 14.5 - 14.7 range. The PCM simply can not see a "boosted" state based on MAP sensor reading and trigger WOT fueling. You are either in Closed Loop or Open Loop (WOT) mode. On the LX, the trigger point to WOT is based on a percent throttle blade open setting.
If I can be in boost at say a 40% throttle blade open percentage, and the WOT threshold is set at 60%, do I have part throttle boost correction? No I do not as I am still in closed loop mode. It is that simple.
Over the past three years, I have run every single piggyback manufactured that is based on skewing the MAP sensor voltage. None are stable as the PCM learns around it. I have run countless PCM tunes some bad, and some very good, from a variety of sources. I won't get into a discussion of who is good and who is not, but I will say that some of them (the best ones) came from a source where you could get no better from anyone. I have pulled so many log files, I have lost count of them. I have studied many dyno sheets where the vital AFR versus boost plots are included.
On those dyno sheets, it is clear where boost is in and where fueling correction is applied. I have yet to see one where the two match up. I have seen some which were close, but generally those had serious driveability issues. WOT runs on the dyno are one thing, and generally you go into boost when the pedal goes to the floor and WOT fuel correction is applied almost immediately. But, out on the street in day to day driving is where the complaints and issues come from as you do not drive it (unless at the track) the way it is run on the dyno. Any tuning needs to be a combination.
The best I have seen have started with street tuning, moved to the dyno, and then back to the street for final tweaking. These have the least amount of overall issues.
As far as bypassing boost, I am working on just such a project. But, you must keep in mind, that on a turbo, if you simply dump the boost to the atmosphere, it is like running the turbo with no outlet connection. You can easily overspeed the rotating assembly in the turbo and it will grenade at some point very quickly. It takes very little exhaust flow to spin a turbo at 150,000 plus RPM if there is no back pressure (work) on the compressor wheel.
Tim
