Standalone ECU interest?
I'm here at SEMA and I had a long conversation with Haltech concerning their stand alone and the viability of doing one for our cars. In talking with him his concern was that one setup wouldn't work for all of the LX cars. Since I'm fairly new to the programming I thought I'd present his questions to me to the members.
1. Should a wire harness developed for all LX cars work across all platforms?
2. Has there been changes in the protocols between the years/makes/models? If so how extensive has these changes been?
3. If they were able to come to market with a stand alone controller without having a plug and play harness would you still be interested?
The key to these ECU's is for guys who are modified (especially boosted applications) you could tune on the road without a dyno and relatively easily including a self adjusting tune. Their ECU's will also control nitrous, meth injection and timing retard/advance.
Here's a list of the top of line models capabilities:
The Haltech E11V2 ECU is an ECU capable of controlling sequential injection on 4,5,6,8 and 10 cylinder applications. With 14 channels capable of controlling injection and ignition duties, the E11V2 can support most modern engines with multi-coil ignition systems, as well as conventional distributor ignition systems.In addition to controlling fuel and spark, the E11V2 can control various auxiliary engine functions such as:
- Stepper motor and BAC/IAC closed loop Idle Control
- Soft cut rev limiter
- Closed loop boost
- O2 sensor closed loop mixture control
- On board data logging (up to 200 samples per second)
- User definable mapping points
- Tuning via TPS with Manifold pressure correction - Ideal for those multi-throttle body turbo cars such as, GTiR Pulsars and GTR Skylines.
- Numerous correction maps to ensure smooth drivability under varying operating conditions Windows Software
Typical Applications:
- Control of fuel injection on modified engines
- Conversion from carburetion to fuel injection
- Race and rally applications of all description
- Design and development purposes
- Educational use by universities and technical colleges
- Original equipment in cars and motorcycle
The E11V2 Flying Lead Kit includes:
ECU Programmable Computer, Flying Lead* Milspec type Main Wiring Harness, 3 power relays, Programming Cable, Fuse Block Assembly on Harness, Programming CD, Instruction Manual (on CD) and Haltech Stickers
Mike & Tina & Kids
2010 Ford Flex Ecoboost V6 twin turbos
2010 Ford Mustang convertible V6 no turbos
