Well, it was 96 degrees at DiabloSport today, but Johan was willing so we put the ProChargum on the dyno with pump gas, reduced timing and an air filter.
Here's a shot of the air filter:
No wisecracks about the jig saw cut, OK?
Here is the first pull:
That yielded 736 RWHP / 738 RWTQ at 12.67 psi, which I thought wasn't bad, given the conditions and seeing that it was a bit rich.
So we fiddled with it and did another pull. Lopez is checking belt clearance against the intake elbow under boost on this one--brave crew chief at work:
Did you hear that rpm modulation at the end? That wasn't Johan pedalling it...that was the torque converter taking a dump. The clutches apparently gave up the ghost. This motor seems to be a touch hard on torque converters. I don't think I'll be able to sell this one, huh?
Here's what it looked like on the graph:
I gotta tell ya, fellas...BillyBob is proud of that dang chart. It takes a special build indeed to make a chart like that!
Talk about a double nut sack!
Whoowee!
I'm glad I have a Paramount Performance torque converter enroute for install this week.
I'm also glad the the pulleys seem to all be spinning properly and Lopez knows how to change a T/C on that thing blindfolded with one arm behind his back.
We should be ship-shape by Ohio next week...doon't you worry about that.
Hey, how about that one good pull on pump gas? Zowie, huh?
