Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Octane boosters
    RFischer is offline Crazy Canuck
    Jul 2008
    Thornhill, Ontario
    Octane boosters
    So I was in the local Canadian Tire and saw Octane boosters that cost a bunch of dollars. Upon looking through the Web I saw that Toluene ( http://en.wikipedia.org/wiki/Toluene ) is much cheaper than octane boosters and does a better job ... I found a link about octane numbers ( http://en.wikipedia.org/wiki/Octane_number ) and interestingly ethanol ( http://en.wikipedia.org/wiki/Ethanol )is used to boost octane ... ... Also - some forums talk about using Laquer Thinner as it contains Toluene, Methyl Alcahol, and Methyl Ethyl Ketone ... any thoughts or experience out there ???
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I've had good results with NOS brand octane booster. It contains MMT. Tolulene, Xylene, acetone, methanol, ethanol all work I'm sure, but the NOS stuff is like $9 and if you add half a bottle to 8 gallons it will raise your octane from 91 to 96 or 93 to 98. Perfect for a shot of nitrous. Warning, the NOS stuff is very toxic and must be kept out of sunlight. I poured half a bottle out into a measuring pyrex cup. then as I walked out into sunlite to pour into my tank, it started to turn dark purple.
    ZMagnum's Avatar
    Tucson, AZ
    The best octane booster is just to buy some high octane unleaded gas at the track. Even at $7.50 a gallon (what my track charges) it's still cheaper than a lot of over the counter stuff.
    Token's Avatar
    Token is offline First AWD LX in the 12's N/A
    Center of the LX Universe
    12.645@108.18
    duce is offline remember the sand ceremony
    Dec 2007
    socal
    ive used toluene and it works great. I wouldnt use laquer thinner as I think it is a very strong solvent and my cause hoses and rummer seals to deteriorate. toluene is very oily like paint thinner.
    slideway's Avatar
    slideway is online now Onward, through the fog
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by duce View Post
    Careful with that toluene, If face is to close and you breath it you may feel woosey!
    (that's the stuff in the old glue punks and dopers sniffed) And worse yet you might like it!
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by Token View Post
    I luv it when you post a link to vulva Dave.
    Quote Originally Posted by slideway View Post
    Good **** man.....................errrrrrrrrrrrrrrrrrrrrrr, try some
    So far I like the Lucas stuff the best.
    wheelife's Avatar
    wheelife is offline Making fast go faster.........
    Oct 2005
    Fredericton New Brunswick
    Or turn into an old punk...
    wheelife's Avatar
    Oct 2005
    HAHA, token reads Volvo forums....J/K..
    slideway's Avatar
    Jun 2007
    Union co. N.J.
    So far I like the Lucas stuff the best.[/quote]
    Lucas, high oct. + buzz = value?
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Works for me
    inferno08 is offline LX Newbie
    Nov 2008
    Dover, De
    The best octane booster that I've use is the NOS race formula. I had a mitsubishi eclipse gsx with a stroker motor and gt35r turbo (decent size) that I tuned myself using a wideband, laptop and a program called dmslink which allowed you to tune and datalog. Best tuning software I've ever used. My goal was to get the most out of the car that I could without using race fuel and have a pretty nasty street car. The nos octane booster made that totally possible. I ran run bottle of this octane booster with every fill up so I could run my race tune all the time. You never know when you may need it.
    On straight pump gas I could run 25psi with about 16* of peak timing by redline getting just a bit knock/detonation (my dsmlink measure knock/detonation). With a full bottle of octane booster to a full tank of 93 octane I could run 29psi and 22* timing by redline with zero knock. That was the point where I stopped pushing it but I bet I could have gotten 33-35psi with a decent timing curve using pump and nos octane booster with more tuning. For you guy's that know about forced induction, running that much boost and timing on pump gas is pretty much unheard of.
    Basically what I trying to say is, NOS Race Formula is the cat's pajammas!!! This was not all based off the ass dyno either. My tuning log's showed the cold hard proof. You can pick this stuff up at Napa or Autozone.
    2008 Inferno Red Magnum R/T
    03 10th anniversary cobra 11.96@119 *sold*
    06 F250 Powerstroke *sold*
    03 Volkswagen 20th Anniversary GTI *sold*
    97 Eclipse GSX 11.98@117 *sold*
    Shelby's Avatar
    Shelby is offline LX Padiwan
    Jan 2006
    Quote Originally Posted by formerice View Post
    Quoting from the 2005 Manual:
    MMT In Gasoline
    MMT is a manganese containing metallic additive that is
    blended into some gasoline to increase the octane number.
    Gasolines blended with MMT offer no performance
    advantage beyond gasolines of the same octane number
    without MMT. Gasolines blended with MMT have shown
    to reduce spark plug life and reduce emission system
    performance in some vehicles. The manufacturer recommends
    using gasolines without MMT. Since the MMT
    content of gasoline may not be indicated on the pump,
    you should ask your gasoline retailer whether or not
    his/her gasoline contains MMT.
    It is even more important to look for gasolines without
    MMT in Canada, because MMT can be used at levels
    higher than those allowed in the United States.
    MMT is prohibited in Federal and California reformulated
    gasolines.
    slideway's Avatar
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by Cam View Post
    Works for me
    LOL! I got a paper bag, Now I just gotta find me some lucas
    JimIsland-SRT8's Avatar
    JimIsland-SRT8 is offline make that a 440 please!!
    Aug 2007
    JAMES ISLAND S.C.
    Not to get off subject, but would a mildly modded SRT, or heads/cam car benefit much from an Octane booster or 110 gas vs 93 octane?
    Personal Best: coming soon!!
