Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By Tout09
  • 1 Post By Jack SickSRT
Thread: Lets talk Race Fuel
    cnhman2008's Avatar
    cnhman2008 is offline America F@$k Yeah!!!!!!!!
    Jul 2009
    lancaster pa
    Lets talk Race Fuel
    Just wondering what you guys are running.I hear alot of the turbo guys are running Q-16 and the nitous guys are C-16 both are leaded so I am assuming its ok to run so a short period at the track. I have a 5.7 with 15-16 psi of boost and lookin to get the most out of it .What would you recomend ?
    truckinfouble's Avatar
    truckinfouble is offline Uncle PoPo
    Jul 2011
    Hastings Fl.
    Leaded will kill cats if you have them. Ive found TT101 for $5.95 a gal in Palatka Fl. Its 100 oct unleaded from Chevron.
    Predator 93 Oct. Tune, Radiator Baffle Delete, Intake Reso Delete, LMI True CAI, Mobile 1, EGR Delete, BT Catch Can, Taylor Shorty Wires, and lots of dreams...
    cnhman2008's Avatar
    Jul 2009
    lancaster pa
    I have no cat's so thats not a issue thanks though
    bklynmag is offline 7.4 RT
    Brooklyn, N.Y.
    I'd talk with your tuner. If your set up can take advantage of race fuel maybe they can adjust timing and/or other paramaters.
    5.7 Personal Best: Heads, Cam and Spray - 11.46 w 1.59 60'
    6.1 Personal Best: Forged, Novi 1500 and Spray - 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Aluminum 449 - 10.736 ET , 1.589 60', 125.05 MPH
    Srt_Driver's Avatar
    Srt_Driver is online now LX Guru
    Apr 2010
    Chicago,IL
    My friend with a fully built sti runs the new shell race gas.i beleive its c16.so far its working out good
    Sent from my DROID4 using Tapatalk 2
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed (SOLD 6-14-13)
    Tout09's Avatar
    Tout09 is online now LX Padiwan
    Mar 2010
    Doylestown,Pennsylvania
    Alot of racers are switching to Shell UTR fuels where they were using C16, it is unleaded and has performed very well, you will need to check the tune to make sure everything is good.
    Tout
    2011 Drag Pack #28 8.79@161mph 6/20/12 MIR
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    E85 and a proper fuel injector.
    '05 Magnum RT: 392 Twin TC70 Turbo Build
    cnhman2008's Avatar
    Jul 2009
    lancaster pa
    Quote Originally Posted by Tout09 View Post
    Tout
    Thanks I'll look in to the shell fuels I havent seen any around though. most local places only carry VP fuels
    Quote Originally Posted by MagnumRT05 View Post
    Been there my twin pump setup dosent keep up with the volume needed to support E-85
    Jack SickSRT's Avatar
    Jack SickSRT is offline LX Guru
    Sep 2009
    Va. Beach Va.
    I run VP C-16 as it burns much cooler for the KB.
    Best ET KB & N02 - 9.800 Best ET KB Only - 9.91
    1st 6.1 in the 9's "Jack the Snake"
    TNCHARGER's Avatar
    TNCHARGER is offline A Confessed LX Modaholic
    Jan 2006
    Kingsport, TN
    Lead also destroys the O2 sensors.....
    2013 CHALLENGER SRT8 AUTO IN BLACK * LMI TRUE CAI * KW COIL OVERS * CORSA EXTREME CATBACK * MAGNAFLOW MID W/ HIGH FLOW CATS * 3.73 GETRAG LSD * PARAMOUNT DOMINATOR 3800 STALL CONVERTER * SPEEDLOGIX REAR SEAT DELETE * SPEEDLOGIX LIGHTWEIGHT FACIA MOUNT * ......MORE TO COME....
    DarthCharger's Avatar
    DarthCharger is offline Supporting Vendor
    Aug 2007
    Cypress, Texas
    How much of a difference in octane rating fuel would require a new tune? For example my Charger is tuned for 91 octane and I only have 93 octane available, I think a new tune is not necessary. But if I go from 93 to 100 it appers that a new tune is required.
    Sheldon@USWForged.com
    Check Out our Latest Wheel Designs
    Visit Our USW Forged Vendor Section
    713.680.8170 main
    2855 Mangum Road Suite B208
    Houston TX 77092
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
    sldhemi is offline LX Padiwan
    Nov 2009
    Needing a tune isn't much related to the "octane rating" as it is to the fuels specific gravity(oxygen content). The amount of oxygen in the fuel will determine whether you need a re tune or not. Obviously if the oxygen content is higher, the motor will run leaner. So fueling will need to be adjusted to keep your air/fuel ratio where it needs to be.
    If you're looking to use one of the unleaded race fuels. Sunoco 104, vp 109, etc. then you will more than likely be fine without a re tune. It will just run a little safer.
    cnhman2008's Avatar
    Jul 2009
    lancaster pa
    C-16 vs Q-16 I know that Q-16 is oxygenated does one burn hotter then the other? I plan on spraying in the future would one be better for that?
    Tout09's Avatar
    Mar 2010
    The Q16 is a very good fuel, just a little sensitive to moisture, containers must be kept closed and I would not let it sit around too long.
    Tout
