Results 1 to 12 of 12
Thread: Innovate ID?
    bobsmyuncle's Avatar
    bobsmyuncle is offline Gute Fahrt
    Oct 2009
    Hamilton, Ontario
    Innovate ID?
    Can anyone help me ID this? Apparently it is an Innovate O2 sensor but I don't see it on their site. Maybe its an older model?
    Hang on St. Christopher !!!
    "I could lick you quicker than Hell could fizzle a feather"
    Sir John A. MacDonald
    "...the Magnum's ideal demographic: a middle-finger-waving anti-establishmentarian, bad-beer connoisseur...The Magnum puts the "blunt" in "blunt-force trauma." By Dan Neil LATimes.com
    SRT Headers/Catback, Silver Box, R Value CAI, NoESP, Johan Tune, BCR coil overs, Hotchkis Sways, Wilwoods/Brembos, Style, Coolness soon to be supercharged...
    Oct 2009
    Hamilton, Ontario
    Bump. Can anyone help out?
    Sjohalsrt8's Avatar
    Sjohalsrt8 is offline LX Guru
    Sep 2011
    WORLDWIDE
    I have a innovate one and it says innovative on the plug, plus Have not seen a plug like that before. I have the mtlx might be different, it has some similarities to your plug the one connector for the plug with the white pin connector on it
    Sent from my iPad using Tapatalk
    GIN
    GIN is offline LX Padiwan
    Apr 2012
    Ny
    Check mopar performance. I think I saw that in the catalog at one point under ems tuning
    Oct 2009
    Hamilton, Ontario
    Thanks GIN no luck there.
    Bump....
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    http://www.amazon.com/Bosch-17014-Ox...B000BZI4ZWpost a picture of the connector so I can see the pins and the shape of the connector.
    Feb 2008
    Oct 2009
    Hamilton, Ontario
    Thanks again for the help so far!
    PAPITO's Avatar
    PAPITO is offline QUALITY HIDS XENON KITS!!
    May 2010
    Orlando, FL
    That is an innovate wideband sensor. I strongly believe that the white plug harness connects to the gauge...I may be wrong though
    EXTREME XENON-Your #1 HID Source
    Chrysler 300C 2006
    PWR Mean Street Heads-PWR Cam-6.1 Intake Manifold-Custom Push Rods
    ZEX Nitrous Kit-LMI Air Intake-6.1 Differential/Drive Shaft-JBA Headers/Hi Flow Cats
    6.1 Oil Pump-OSTMIKE Custom Tune-All Labor Done By AHMP
    http://www.lxforums.com/board/f58/**...ble***-312661/
    OsO's Avatar
    OsO
    OsO is offline If you will slow down i will look faster
    Jun 2008
    Houston TX
    2009 SRT Chally Stock and it sucks right now!!!
    F&%@ you were from Texas!!
    Oct 2009
    Hamilton, Ontario
    Quote Originally Posted by PAPITO View Post
    How certain are you?
    That DOES look like it!
    As you probably have guessed I have the sensor, but no gauge (the way my used kit came).
    Feb 2008
