Page 1 of 13 12311 ... LastLast
Results 1 to 15 of 181
    smoove7410's Avatar
    smoove7410 is offline 2.0 x 3.0 x 5.0 ÷ 10.0 + 1.0 = 2.0²
    Apr 2004
    Los Angeles
    **sms 296 Twin Screw Supercharger**
    Here is Saleen's take on supercharging mopar.
    PRESS RELEASE:
    Orange County, California. (August 7, 2008) Automotive icon Steve Saleen and his new company SMS are proud to introduce the first product in the SMS line of ultra-high performance technical parts, the SMS 296 Supercharger™, designed, engineered, manufactured and assembled in-house at our 150,000 square foot facility. Mopar owners of 2005 to 2009 HEMI 5.7 and HEMI 6.1 vehicles are now able to boost under hood horsepower by up to 45% with innovative new dual-screw supercharger (patent pending).
    With over 30 years of racing experience Steve Saleen and the SMS design and engineering team have created the ultimate supercharger for Mopar enthusiasts. Now the aftermarket community can take advantage of the SMS 296 Supercharger™, which will be standard equipment on the highly anticipated 2009 SMS 570 Challenger™ and SMS 570X Challenger™, with power ratings from 500 to over 700 horsepower respectively!
    The SMS 296 Supercharger™ is packed with innovative features created by SMS engineers to provide optimum boost in an exceptionally compact package.
    At the top of the list is the Delta-Frame™ internal intercooler (patent pending), with dual thin-core intercoolers and single-pass coolant flow. The intercooler design provides for a considerable increase in surface area, which has the effect of minimizing pressure drop and optimizing thermal characteristics. The intelligent configuration also acts as a mechanical diverter for effective air transfer into the ports, while the angled manifold enables packaging of runners that are much longer than in conventional layouts.
    The long intake runner optimizes airflow efficiency and provides the SMS 296 Supercharger™ with an extremely low profile. This arrangement means that it nestles comfortably within the V, and under the stock hood of all applications, as well as accommodating a bypass system for 3-way cruising off-boost.
    At the heart of the supercharger are the asymmetric multi-lobe compressor screws, which are machined in-house by SMS on state-of-the-art CNC equipment. The screw concept is among the most efficient of all supercharger configurations. However, it is also one of the most challenging to manufacture.
    In order to minimize parasitic losses, it is crucial to maintain incredibly tight tolerances between the profiles of the asymmetrical lobes. Running dry at speeds of up to 16,000 rpm, there is no room for error. In finishing the screw profiles, the SMS flexible CNC machining facility is working to exacting tolerances. The flexibility of the equipment also means that changes in the screw profiles can be accommodated for different applications.
    The innovations on the SMS 296 Supercharger™ carry through to its exterior, with SMS Tailor Made™ custom finishes and powder coat color options to match most Mopar colors. Now enthusiasts can match the impact under the hood with the one at the rear wheels.
    The complete SMS 296 Supercharger™ aftermarket assembly looks great and installs easily under the stock hood of all applications including; the Dodge Challenger SRT-8, Dodge Challenger R/T, Dodge Charger SRT-8, Dodge Charger R/T, Dodge Magnum SRT-8, Dodge Magnum RT, Chrysler 300C SRT-8, Chrysler 300C, Jeep Grand Cherokee SRT-8, and Select 5.7L Hemi Dodge Trucks.
    Please visit www.smssupercars.com for more information. For a broad understanding of the workings of superchargers please visit http://en.wikipedia.org/wiki/Supercharger
    SMS 296 Supercharger™ key features: Patent Pending
    • SMS-2955 cc / 180 cu. in. Displacement
    • SMS-Integrated Front Drive/Induction Combo
    • SMS-Dual Screw Configuration
    • SMS-Asymmetric Multi-Lobe Compressor Screws
    • SMS-Delta-Frame™ Internal Intercooler Configuration, Patent Pending
    • SMS-Remote Drive 8-Rib Pulley and Dampener
    • SMS-Internal High-Volume By-Pass Valve
    • SMS-Low-Profile High-Volume 10 Inch Long Runners
    • SMS-Dual Thin-Core Intercoolers with low pressure drop
    • SMS-Single-Pass Intercooler Coolant Path
    • SMS-Symmetric CNC Intercooler Caps with integrated coolant passages
    • SMS-High-Volume Intercooler Water Pump with recovery tank
    • SMS-High-Volume Heat Exchanger with all hardware
    • SMS-80 mm Venturi with high-flow air filter
    • SMS-88 mm Cold Air Inlet Tube
    • SMS-SuperTune OBD Compliant Calibration and Program Tool
    • SMS-Extruded Aluminum Fuel Rails with upgraded fuel injectors where applicable
    • SMS-Ultra-Light Weight Aluminum Construction
    • SMS-Stainless Steel Fasteners
    • SMS-Instruction Manual
    • Utilizes factory throttle body and hood
    http://www.autoblog.com/2008/08/07/b...harger-system/
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Toooooooooooo Sick!!
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    I dig it. I won't believe it until I see it hit the streets. Looks Like $$$$$$.
    Colors too
    Redfox0099's Avatar
    North Charleston, SC
    I gave them a call incase they need some "Custom Clusters"
    We'll see if they call back
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    That is so sick looking....
    I think I may want one!!!!!!!!!
    Thank you Bigal470
    Rollin on Dueces's Avatar
    Rollin on Dueces is offline Just browsin'
    May 2006
    Benson, NC
    OMFG! That is insane!
    2005 Chrysler 300--gone but not forgotten
    srt-hardware's Avatar
    srt-hardware is online now Fast is the game
    Jan 2007
    Upstate NY
    This Changes Everythinggggg!!!!!!!!!
    My Mods:
    Procharger F1-C supercharger @ 15psi running thru a full custom ductwork including a Danko productions Shaker hood kit transformed into THE FAKER SHAKER you see today by 402 Motoring and a 24"X18"X4" air to air intercooler then to the throat of a single plane intake by XV Motorsports, 8.5:1 Comp ratio, H-beam rods, Ross racing pistons, P&P heads & intake, Diablo tuned by Dave @ B&G, complete return fuel system using a Weldon racing pump and pressure regulator, Methanol injection removed, Nitrous perimeter plate capable of 100-300hp (at 175 now), RUNNING 10'S ON THE DRAGSTRIP
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Quote Originally Posted by srt-hardware View Post
    Yes it does.....
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryO² Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    BurntOrange's Avatar
    BurntOrange is offline LX Padiwan
    Nov 2005
    Jacksonville, FL
    Saleen, hmmmmm. would be great condsidering they have been producing some sick cars for a while.
    Go-ManGo! 2528
    SRT Suspension, Airaid CAI, Diablo Predator, Magnaflow Catback, Stealth Auto Headlights, Blinker MOD, Nitto 420s, OEM Chromed CSRT Wheels, Custom CF Engine Cover (By ME.), SRT Diffuser, 180 T-stat, some day Cam and Heads, BT Dash Tag.
    FastWagon is offline Stirrer of the Pot
    Dec 2007
    Bartlett, IL
    now that is sick. its about time!
    crhemi's Avatar
    crhemi is offline LX Padiwan
    Dec 2005
    Kauai, Hi
    04hemipwr's Avatar
    04hemipwr is offline From Hemis to turbines...
    Grand Rapids, MI
    looks very cool.. wow..
    but to spend as much money as the cars worth on a supercharger.. lol i bet its way over 15k..
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    80+mm turbo > twin screw
    Its a great idea, but just not worth the money when you can make more power for less money with a turbo setup.
    -392 Twin TC70 Turbo Build
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by MagnumRT05 View Post
    The Iron Mistress Galleries
    R.I.P. Dave...
    SRT8U's Avatar
    SRT8U is online now www.speedlogix.net
    Jun 2006
    South Florida
    Nice...my bet is still on Saleen to produce the Mopar Branded Supercharger...
    Oh BTW...who is a Saleen Dealer...BMC Performance of course
    This product is from Steve's new company..looks like we ned to find out more about these bad boys!
    Kris | Mopar Specialist | Speedlogix, Inc.
    2006 Charger SRT8 Vortech Supercharged by SpeedLogix
    *** We Price Match - click here to see how it works! ***
    Speedlogix, formerly named BMC Performance ... same people, new name!
    Visit us online at Speedlogix.net or call 888-SPD-LOGX to talk to one of our Mopar experts!
