Results 1 to 15 of 20
    ZeGuru's Avatar
    ZeGuru is online now It's me, no really - it is.
    Downtown Saint Paul, MN
    Picked up a set of winter rubber tonight!
    Picked up a set of Blizzak's today off Craigslist and tomorrow I'm putting them on. Question: Should I have them filled with nitrogen? It's about $5 a tire to do that.
    I'm pretty stoked about it, they are almost new, the lady said she had them for about three months then sold the car. From the looks of the tread, she put almost no miles on them. I paid $400 for them
    I'll post up some photos tomorrow.
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    NICE!!!!!
    not sure on the nitro!!!!
    maybe helium????
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    ZeGuru's Avatar
    I've heard too many good stories not to try it. Maybe if times get tough, I can use it as whipits.
    lou1355's Avatar
    lou1355 is offline Hoosier Daddy - Finder of Weak Links
    May 2006
    South Florida
    The nitrogen is thermally stable, largely because the pull a vacuum before refilling each tire and that removes the humidity. You end up with a very low moisture environment inside the tyre, which reduces pressure fluctuations. It also doesn't leak down as much as air. Why that is, I do not know.
    "show"'s Avatar
    "show" is offline Not your normal family car!
    Feb 2006
    Winnipeg Manitoba Canada
    Quote Originally Posted by lou1355 View Post
    where did you here or see that? i worked at a tire shop and we did not do that. i had it in my 22s at the end of last year and i don't think it is a big deal.
    PERFORMANCE: HEMICHEF COLD AIR INTAKE, 180* T-STAT, PREDATOR PROGRAMMER, FLO-PRO MAX EXHAUST, GUTTED CATS, BT CATCH CAN, 245/45/20 EAGLE
    RS-A, 315/35/20 ATTURO Az800
    EXTERIOR: 2008 300C SRT8 FRONT BUMPER, LSD LAMBO DOORS, KLUCK FABRICATION FENDERS, T-REX BLACK MESH GRILLE, CUSTOM PAINTED 300C SRT8 RIMS,
    TINTED TAILS, 4500K HID FOG LIGHTS & HIGHBEAMS
    STEREO: KENWOOD DOUBLE DIN DVD DECK, 7" HEADREST DVD MONITORS, 19” TOSHIBA LCD MONITOR, 2 12" INFINITY SUBS, ALPINE AMP, CUSTOM FIBERGLASS
    SUB BOX
    TIME SLIP: 12.7278 @ 110.66 with a 1.89 60'
    http://s7.photobucket.com/albums/y251/keithanderson/
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    All nitrogen is in there for is to be as inert as it can be. even if they don't pull down a vacuum (hard to do, you end up popping the bead)... youa re dropping the humidty by at least half in there. Also, there is much less oxygen and other chemically active bits... so... take that how you may.
    I don't do it cuz I'm cheap and I air up/down.
    lou1355's Avatar
    May 2006
    South Florida
    Quote Originally Posted by "show" View Post
    Personal eye witness account. I had my crew chief put N2 in my Hoosier drag slicks for thermal stability. His N2 machine first sucks out the air & humidity, then refills the mounted tire with pure N2.
    Not taking that step reduces the effectiveness of the N2 fill.
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    How did they keep the tire sealed?
    lou1355's Avatar
    May 2006
    South Florida
    Quote Originally Posted by lafrad View Post
    OK. I called my crew chief to make sure I don't give any false memories here.
    He pulls enough vacuum to begin to pull the center of the mounted tire towrds the rim. Let's call that a partial vacuum, but it's enough to suck the humidity out of the mounted tire. If he kept pulling the vacuum at that point, the beads would eventually break seal and you would lose the vacuum, and the point at which that happens depends on the sidewall design and stiffness, but you can definitely stop short of that if you are paying attention. Once that partial vacuum is pulled, you wait a minute or so, then fill the tire with the N2.
    My understanding of the function of the N2 is that it is thermally stable (will not move the pressure gauge around much on hot/cool cycles) and for street use, in addition to being thermally stable, it will not leak down as fast and inhibits corrosion of your wheels (dry environment).
    ZeGuru's Avatar
    OK, got em back, full of nitrogen and brand spanking new tie rods
    There was SOOOO much slop in the front wheels I had to bite the bullet. So my $100 tire mount and balance turned into $520.
    Oh well, the car is much quieter now with those fixed Now I just need to get the mopar cai and struts I bought a month ago installed.
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    Winter tires are nice!
    I put mine on about a week ago. While I like having them on, I sure hate looking at my ride without the Foose on there.
    05magmn's Avatar
    05magmn is offline WTF, OMG
    Frost Bite USA
    What I was told is that air molecules are small enough to fit through the holes of the rubber molecules, but nitrogen molecules are bigger and wont fit through. or some thing like that. heres a link to some info.
    http://www.getnitrogen.org/why/index.php
    Quote Originally Posted by Bandit View Post
    I have been pulled over MANY, MANY times.
    SURPRISE, SURPRISE!!
    gn300's Avatar
    gn300 is online now Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    What he said!
    If you are mounting them on Winter wheels i'd use nitrogen.
    But if you plan to use the same rims for the summer than that would be a waste!
    Better control of tire pressure = better milage and longer tire life!
    ZeGuru's Avatar
    Yeah, the plan is to have these as winter duty only. Come spring, I'll be on the prowl for some fun wheel/tire combo. Ideally, I'd like to find some CSRT take-offs, but I'm (by nature of marriage) a cheap skate so we will see.
    I was thinking of getting some BT center caps that have the winter tire logo on them, just for fun.
    OH!! The tire shop also broke one of the lugs (the outer part), so I have to get that replaced this weekend.
    Fondy's Avatar
    Fondy is online now YUUUUUUUUUUUUUUUUUUP!
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    welcome to the snow club I just got on my Blizzak's on too. 255/55/18 they are beefy
    :insert sig here
