Nop...its exactly what the name says..its a "x" pipe before the suitcase aka muffler..
On ma fone g!
*New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
(SOLD 6-14-13)
helps balance the back pressure like an H pipe and also scavenges the exhaust to help the engine breathe better
"Scars heal... glory fades, and all we're left with are the memories made, Pain hurts, but only for a minute, Yeah life is short so go on and live it; Cause the chicks dig it" - Chris Cagle
got it, so what benefits would there be for a daily driver? thinking of getting the resonator delete kit from BB and maybe new mufflers
your R/T already has an X pipe.
without it you will find a slight loss in low end torque, and probably a drop in MPG.
the X is between the suitcase and the rear resonators. replacing either has no affect on the X, it will stay in place.
first I recommend removing the X-pipe and install a H-pipe as close to the mids as possible this will eliminate you Drone.... but if you get rid of it altogether, especially if you remove your resonators you will loss low in Torque....also I have noticed a slight increase in MPG with the H but this depends on how you drive
Hemi Registry #1348 SuperFrawgie 1361
thought about that on my way home from work, havent really looked under there to see, but from what i have seen i think it might be in front of the muffler, between the cats and the suitcase?
my wife drives it mostly too and from work, about 10 minutes each way in town, we take it out on the highway and some mountain roads once in awhile!
