Results 1 to 15 of 21
    jules2315's Avatar
    jules2315 is offline 2006 RT
    Calgary,AB,Canada
    Would the 300x4 kit be too loud for wife and baby???
    I would like to get the 7db kit with the 4" tips but have no clue when they will arrive if ever, so I am wondering if the 9db kit will be too loud?
    My wife does drive the Magnum sometimes also so I am needing something that will not be too loud for her and also for me for work as I am visiting dental offices for work each day.
    Thanks for any advice Bob
    omega145's Avatar
    omega145 is offline LX Padiwan
    Feb 2009
    Long Island, NY
    I had this kit and loved it. Not too loud unless u are WOT.
    omega145's Avatar
    Feb 2009
    Long Island, NY
    Forgot to mention, my 10 month old daughter didn't mind .
    Blastin_Bob's Avatar
    Blastin_Bob is offline Supporting Vendor
    Nov 2006
    Quote Originally Posted by jules2315 View Post
    Are your stock tips rolled on the edge?
    jules2315's Avatar
    Calgary,AB,Canada
    they are rolled with a slight angle to the tip itself.
    Thanks Omega
    JarZ's Avatar
    JarZ is offline Home of the SPARTAN and SRT MAX
    Union County, NJ
    Got the 6db kit. No complaints from wife (or kid).
    5.7L & 6.1L Hemi Registry # 856
    JarZ@Inertiamotorsports.com
    Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
    Find us on Facebook Or @inertia392 on Twitter and www.inertiamotorsports.com!
    Past Mopars:
    2005 Dodge Magnum R/T
    2006 Dodge Magnum SRT-8
    2000 Chrysler LHS
    1999 Dodge Intrepid SE
    Leadfootluke's Avatar
    Leadfootluke is offline LX Guru
    Grand Rapids area
    Thanks Omega
    Bob is seeing which of the 3 mufflers you have. You have the quietest to begin with I believe. Because you keep your stock muffler, your 7db or 9db kit would be the quietest of the 3 mufflers.
    HammerStyleIntakeBilletTechBlastinBobTommyZDesign
    Nov 2006
    Exterior wise the 9 db isn't super loud with your setup, however you will get some interior resonance/drone with this kit. I've given up hope on ever getting the tips for the 7 db kits, the closest I can get you to that sound would also be the one I would recommend and that is a mandrel bent 5db kit with 4" DW tips. #225DW4 The mandrel bends will add a little sound over the press bent kit without getting the dreaded MDS drone.
    Bob
    jules2315's Avatar
    Calgary,AB,Canada
    i do not like the tips on the 225dw4..if i got the 300x4 with the mandrel bend to it..would that reduce the interior resonance?
    Thanks a bunch Bob
    Nov 2006
    Thanks a bunch Bob
    No.
    jules2315's Avatar
    Calgary,AB,Canada
    well i do not know what to do..wait for something to hopefully come, or get the 9db kit and hope it is not too annoying inside the cab.
    Nov 2006
    Here is what I can do, I have already done a couple this way, I'll make a set with the same tubing as the 7 db(2 1/2") and use the tips from the 9db kit. It will require me to flare the tubing up to mate with the 3" opening. The internals and the two tips are the same diameter, only the first 3 inches are bigger on the tips that I have.
    You'll have to call this one in if you want me to make it this way.
    562-866-2812
    Bob
    jules2315's Avatar
    Calgary,AB,Canada
    thank you Bob...I will give you a call and much appreciated for your help and this offer...you are the best!!
    Zodiack24 is offline LX Newbie
    Quote Originally Posted by Blastin_Bob View Post
    562-866-2812
    Bob
    Sounds like a great solution for the 7db kit....are there any pros or cons to making them this way? Would these sound louder than the original 7db and more quiet than the 9 db? (making them about 8db?)
    Nov 2006
    Quote Originally Posted by Zodiack24 View Post
    I doubt the sound will change doing it this way. The only con would be the step up to make it fit, although it's just cosmetic.
    Bob
