Can someone tell me from this picure which one is the radius rod and which is the control arm? Or identify the arms if they are not either that I listed. I am interested in the Peddlers stuff but the Website is a long way from helpful when it comes to IDing this stuff. Thanks.
Jay
2013 Honda Accord EX - 2.4L/6-Speed Manual
2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed - Gone2005 Dodge Magnum RT-Can you say...HEMI? - Gone2004 Chrysler Pacifica AWD-Everything but the kitchen sink.1989 WS6/L98 Trans Am-Got Torque? - Gone
Thanks, guys.
FWIW, can this be a DIY job? I can get the arms off myself, and have access to a full maintenance shop with presses and tools, is it possible to change them that way? I live near Albany, work 60+ hours a week and have a 2 year old. Getting to a peddlers shop is not going to happen.
BTW the 'tape' is a DCX part tracking sticer from when warranty work was done two years ago because the bushings were bad. The car was making a groaning noise when turning left. They replaced both just to have the noise come back a week later. Then they changed the control arms. I am back in the same boat again.
One last thing, if I put the front on jack stands and let the tires hang down freely, are the struts at full extension then? IE: Just undo the bolt, remove the ball joint from the spindle, remove the bolt and its out?
Jay
Hi Jay.
Taking the radius rod and lower control arms out is pretty easy. But the bushings will require a 10-12 ton press. A lot of guys do not have one. I do! LOL. But what you can do it take it to a machine shop and have them press the bushings in and out. I can help you in terms of what direction and clocking. So the answer is yes, with a hydraulic press
mike
dms
Clocked meaning tapered?
Jay
I found the bad bushing, passengers side control arm. The arm is right up against the cradle, you can slide the bushing on the steel sleeve.
Do you guys sell a discounted kit with just the radius arm and control arm bushing? I do not need the bump steer bushings.
http://www.facebook.com/photo.php?pi...&id=1439693460
Looking over the job: I remove the sway bar bushing mounts, remove the bolt for the control arm, strut and the ball joint. How do I get the ball joint out of the spindle? Go old school with a Pickle fork?
Jay
To get the balljount out, loosen the castle nut, then you can use a balljoint disconnect tool. Most shops, however, will wack the control arm at the balljoint eyelet with a big hammer, and normally the impact pops the balljoint loose.
Here are some systems that include the 2 bushings with discounts:
6/3/09 MERLIN P/N LXFRBUSHKTUP
this kit will replace all the bushings in the LX front end, and will give you full alignment capabilities for the front.
Part Number Description Price
EP2113 LX Bump Steer Correction Kit $81.56
EP4107 LX Front Lower Shock Mount $85.03
EP6567 LX Front Radius Rod Bush $156.84
EP6568 LX Front Lower Control Arm Bush & POLICE Intercept Fron Radius Rod Bush $156.84
EP6570 LX Front Upper Control Arm Bush with Adjustable Camber Capability $273.98
Pedders Front bushing Kit Parts Total $754.25
Menu System Discount $204.26
Menu System Discount Adjusted Parts Total $549.99
LX Critical Front Repair Kit
1/21/09 MERLIN P/N LX CRITICAL KIT
Total Pedders Parts $395.24
Menu System Discount $145.25
Menu System Discount Adjusted Parts Total $249.99
Both systems above have serious discounts,
mike
dms
Mike-
Do you have any info on my order? Thanks.
Jay
