Yep. I was doing headers too so it all made sense.
I had heard this was one you had a hand in. This one is 112 LSA, though. Nice little off-the-menu item...
I was doing headers anyway and while springs can be done without pulling heads, sounds like a PITA...
Now that I have headers and 6.1 springs in place, if I ever changed the cam again
(no plans to) I would not pull the heads. The lifters lay a lot more horizontal than the old-school V8's so I would trust magnets to hold them away. I do miss the old motors where you pull off the intake and all the pushrods and lifters are sitting right there.
Eibach Pro-kit springs,dampeners, and sway bars,BWoody front sway links, K&N Intake, Predator tune by Stu, 180 T-stat, BT park lock replacement and catch can, Pedders tension strut bushings & bump-steer kit, Blastin' Bob's 4db resonator kit, Inertia Super Spartan cam,6.1 springs & pushrods,JBA shorties, 6.1 pulley, '08 Charger 18's with 235/55/18 Toyo Versados front, 255/5518 Yokohama YK580's rear, R1 Concepts premium front rotors, PosiQuiet pads
I'm running the cam I got from Powerwagon896 Super Spartan in my 5.7 and it's a beast! Very Streetable and a TON of torque whenever you want it!
2005 Magnum RT ALL options! Shaken, STU'd, Paddled, and Dropped! See my HEMI Registry for other mods list: http://www.lxforums.com/board/f76/5-7l-hemi-registry-1090-injunwiz-154589/
Your's is on a 113 LSA Jon. Makes the TQ come on a bit sooner.
Set your rev limiter to 6700 RPM, get those 3.06s in, slap on some 25.7" M/T Drag radials & hang on. Come out of the chute in drive, then slap the shifter left to hold 2nd gear in autostic. het that MTCM sorted out, hold 2nd gear for a 6500-6600 RPM shift to 3rd (you'll have to time this shift about 500 RPM below that point to get the shift @ 6600 RPM) & hold 3rd all the way to the traps.
If you get the car down near 4000# & your tune is right, you should be knockin' on the 11 second club's door.
i have the ss cam 112lsa with inertia performance heads and stu's tune. i just now started running it a little harder since i just got thru with the break in stage. I got a new 5.7 motor from him as well i cant wait to get it down to stu to have it dyno tuned for a peace of mind. the email tune runs great though, it feels like it has a ton of power.
6.1 swap......
1.599, 7.46 92.18 mph 1/8
4250 lbs
"you're going to come across people in your life
who will say all the right words at all the right
times. But in the end. it's always their actions
you should judge them by. it's actions, not
words, that matter."
This cam was cooked up by Stu & myself back in the late winter early spring of '08/'09.
What is is basically is a Comp 268 on steroids. Same basic duration but a more agressive opening ramp on the lobes & a bit more lift.
It was supposed to be 216/220, but it came out to 215/219 @ .050" lift. Lobe lift is 3.40"/3.39 respectively IN/EX netting .561/.570 @ the valve, 113 LSA & ICL is 111. (these spec's came from the cam card) There is minimal but adequate (IN) PTV clearance @ TDC on th EX/IN cycle when plugged in straight up.
The whole idea was to achieve the mid range TQ of a "bigger" cam W/O sacrificing the low/midrange TQ of the Comp 268 class cam. Max HP is @ 6250 RPM W/a flat power band to about 6600 RPM.
The cylinder cranking pressure is in the 230# range yet W/a .030" head deck reduction (.035: quench) it takes lots of spark advance in stride. (bear in mind that I run a 160* TSTAT @ the track & on the dyno to combat detonation @ the low end)
& the ICL is escapes me but there is minimal but adequate PTV clearance @ TDC on th EX/IN cycle when plugged in straight up.
By Golly 235# Was Not Far Off!
The drivability is excellent & it barely give's up the fact that the car does not have a stock cam due to a well mannered 750 RPM idle.
Fuel economy is also great W/25+ MPG @ interstate speed W 3.23 gears in the diff. It's a good moderatye grind that is a compromise between drag strip & DD performance.
The numbers in my sig were achieved W/this cam.
I sell and install a ton of Stu's parts, nothing but good things to say about Stu, it's just really hard maybe impossible to get a N/A 5.7 in the 11's at Fontana. Regular DA of 2500 to 3500 and the finish line we just surveyed Jan 7th is 12 ft higher then the start line at the staging lights. Fontana is the only 1/4 mile track in Southern California unless you count Famoso.
So does this cam make more power/torque than the SRT MAX in a 5.7 if both are set up with the same heads and intake, or is the super spartan offer more bottom end, mid range or top end?
Im kicking myself right now thinking if I went with this cam I could be in the 11 second club......![]()
JBA shorties catless mids and SLP Loud Mouth I, K/N typhoon, powerbond undrive pulley, 170 tstat, mopar TCM, blue tops, R1 crossdrilled/slotted rotors, HAWK Pads, SRT MAX on 112, CNC Inertia Heads milled, 3000 Edge converter 3.91 Getrag 09 axles installed!#157 of 1400
157 0f 1400
http://s182.beta.photobucket.com/use...20563452620283
