Results 1 to 13 of 13
Thread: Srt maxx cam
    Sjohalsrt8's Avatar
    Sjohalsrt8 is offline LX Guru
    Sep 2011
    WORLDWIDE
    Srt maxx cam
    Hey guys well I wanted to ask what is the highest boost level that anyone has run with a srt maxx cam? I have seen a few threads were people are running boost with this cam and it works great!. What are the hp gains with just this cam? And what else would be needed to do the install? Does it require pushrods or upgraded retainers and springs.
    Knight is offline Mopar FTW
    Dec 2010
    Maumee
    I just threw mine in last month. No upgraded springs/etc. From what I have read its the biggest cam you can go on SRT stock valve train. If you go to the power adder section you can see I have a post on power levels. One guy was making 577 with 8 lbs and this cam
    [/quote]
    2007 SRT-8 Charger Group I, II, and III
    - SLP Loudmouth I Exhaust/ Procharged HO Kit 6psi/SRT Max Cam/3.91 Getrag Swap/3200 Dominator Converter/Ksport Coilovers/BT SRT Shift Knob/ 22x9 and 22x10.5 TSW Jarama Rims/Danko SRT Chin Spoiler
    JarZ's Avatar
    JarZ is offline Home of the SPARTAN and SRT MAX
    Union County, NJ
    If you have a 6.1 you don't need new springs/rods etc. You'll gain 40-45 RWHP just from the cam. Not sure what the max boost is but it has seen some success under boost, absolutely. It's not designed for boost per se, but it works well.
    5.7L & 6.1L Hemi Registry # 856
    JarZ@Inertiamotorsports.com
    Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
    Find us on Facebook Or @inertia392 on Twitter and www.inertiamotorsports.com!
    Past Mopars:
    2005 Dodge Magnum R/T
    2006 Dodge Magnum SRT-8
    2000 Chrysler LHS
    1999 Dodge Intrepid SE
    Sjohalsrt8's Avatar
    Sep 2011
    WORLDWIDE
    Quote Originally Posted by JarZ View Post
    It's 5.7 heads(05) bro what would I need for the install of this cam
    Sent from my iPad using Tapatalk
    JarZ's Avatar
    Union County, NJ
    PM'd you back
    392Stu's Avatar
    392Stu is offline Supporting Vendor
    Nov 2006
    On boost I'd go with 8-12 degrees of split on a cam. The SRT Max will work with boost but more split will work better. Last year we went 214/222 duration on a 115 LSA for an SRT Jeep which is real small but it gained 70 rear wheel over the stock cam at 6 psi boost.
    I've really starting to believe in running more split than we have been. I've got an new grind that similar to an SRT Max but 4 degrees more exhaust duration and it's good for 5-10 more HP than the SRT Max and doesn't give up any low end or mid range. I've been calling it an SRT Max Plus for lack of a better name. I do know that I've installed and tuned 2 of them in house now and normally cam only SRT Max cars will make right at 410 wheel HP on the dyno I tune on. one for the max plus cars made 430 but had long tubes which don't help much (maybe 5-10 HP) and it had an underdrive dampner which is good for maybe 5 HP. So it was definately 5-10 up on the standard SRT Max. The second one I did made 418 and that was stock exhaust, cam only the only other mods being a CAI and Predator. I've never broke 415 cam only on that dyno with an SRT Max to put it in prespective. So the NA engines are liking 8 degrees of split and if NA works better on 8 a boost application will be good with 10-12 for sure.
    Six Offenderl and builder of the finest Fiat Hemi stroker engines.
    Hypnotiz3r's Avatar
    Hypnotiz3r is offline LX Padiwan
    Apr 2009
    Winnipeg, MB, Canada
    Damn, wish this new grind was out when I bought my cam. Sounds pretty good.
    2006 Dodge Charger SRT8 (Black)
    Kooks headers/catted mids
    SRT Max cam
    Corsa Xtreme
    SLP Underdrive Pulley
    LMI 4" Fender mount CAI
    WTB Traction!
    08.27.2011 -- 12.45 @ 111 MPH 1.85 60' (17" MT ET Streets)
    Sjohalsrt8's Avatar
    Sep 2011
    WORLDWIDE
    Quote Originally Posted by 392Stu View Post
    That sounds pretty impressive I think I will give that one a shot. Does it have a nice lope to it like the srt max stu?
    ALABAMA MSRT8 is offline ALA8BAMA MSRT
    Aug 2008
    BIRMINGHAM ALABAMA
    im looking to buy an SRT MAXX cam.where can i purchase 1 at,any vendors carry them?
    JarZ's Avatar
    Union County, NJ
    Yes it's our cam. You can send me an email or call 512-964-7724
    btr's Avatar
    btr
    btr is offline LX Guru
    Aug 2009
    MASS
    I have an srt max cam and I have an 8psi pulley, after I hit the dyno I'll let you know how I do.
    Sprayed_SRT8 is offline Rattle rattle clank clak
    Jan 2011
    Colorado Springs, CO
    what is I'm hearing. Curse you Stu lol. i might have to upgrade.
    12.001 @ 116.81 2011 season 491HP 534TQ
    2012 593HP 605TQ UPDATED as of June 2012
    http://www.serviontuning.com/
    http://www.inertiamotorsports.com
    Aug 2008
    BIRMINGHAM ALABAMA
