Page 5 of 5 FirstFirst ... 345
Results 61 to 68 of 68
  1. #61
    Cruisin1966's Avatar
    Cruisin1966 is offline Anonymous
    Oct 2008
    Okotoks, AB
    Quote Originally Posted by HeavyHook View Post
    In my case I don't have a Zeitronix. I'm using a DynoJet. Any ideas on the color wise to use from the DynoJet to Trinity.
    BTW, I'm a little color blind...or so I'm told. LOL
    Page nine in:
    http://www.powercommander.com/downlo...8200017.03.pdf
    Looks like you need a Data Acquisition cable (76950114), if it didn't come in the kit you have.
    2012 Stinger Yellow SuperBee - Trinity; 8% Tinted Windows; HID's; 4.3S Stereo; Flowmaster Outlaws
    (Soon: MSRT rims; BC Coilovers; Sportwing Roofline Spoiler; ZT-3)
    2007 Sublime Daytona #082/150 (The Wife's) - VFN AAR Hood; Danko Cuda Grill; Sportwing Roofline Spoiler; Painted/Tinted Tails, OBX LT's/Super 44's/4" tips; Martin Bro's Rims
    2005 Cool Vanilla Magnum R/T - sold
    2011 GWE Challenger R/T Classic - traded
    2009 Hemi Orange SRT8 SuperBee #178/425 - traded
    2006 Silver Steel R/T w/ R&T - traded
  2. #62
    Hemissary's Avatar
    Hemissary is offline ..if you are within 1-2 thou...you're OK
    Calgary, Alberta
    Thanks TJ for pointing me to this thread; to the OP; great How-To article btw; you might consider changing the wording when referring to the white lead (pin2) exiting the ZT-2 controller from "Analog input" to "Analog Out". Might be confusing for folks.
    The other thing that is a concern; although the upper and lower wideband limits can be set within the Trinity, there might be problems because the Trinity is assuming a linear-relationship device is being connected to the analog I/P (3-pos 2.5mm plug).
    The model year/iteration of various ZT-2 units is very important to know to ensure that the 0-5V reference being sent to the Trinity is indeed a linear relationship.
    That white lead (FYI it's not a wire; a wire is a single strand, multiple strands make up a lead, a cable is 2 or more leads) can be either linear OR non-linear depending which iteration of ZT-2 controller you have; Zeitronix Zt-2 Wideband Analog Output
    Failure to select the correct lead (white or purple) could cause erroneous readings right in the area we need the most accuracy from the Bosch LSU (PN 17014) O2 sensor (most of the aftermarket wideband systems are suppying this PN with their systems).
    As far as adding the 0-5V reference signal from the Dynojet controller to the Trinity; Cruisin1966 has pointed to the correct PN (sect. 6), however it might be prudent to get the 3-wire version that has an external system GND (sect. 10, PN: 76950118). Again, because the Trinity only accepts min/max, those values might need to come from Dynojet (it's possible they are the same as for the Zeitronix/Bosch system - but need to ask).
    Note; it is very important to ensure the grounding (either reference or system) on wideband systems is done not only correctly, but securely. This is one the biggest problems casuing inaccurate/fluctuating readouts.
    TJ; if you don't have that 2 or 3-wire comm cable I can make one (I manufacturer wiring harnesses for R/C aircraft/military UAV's). It's likely male/female pin systems on 0.100" spacing...
    ---VIPER--VENOM--RED-- ------------------------Click-- Hemissary--to read complete story at--CarDomain----
  3. #63
    HeavyHook's Avatar
    HeavyHook is offline Need more time to drive the "Bee"....
    Apr 2009
    Chestermere, AB. CANADA
    There you go talking Asian to me again. Remember Simon, I'm just a redneck heavy tow operator!
  4. #64
    Hemissary's Avatar
    Calgary, Alberta
    Sorry TJ; in simple terms the 2006 to 2009 Zeitronix ZT-2's pin2 (white lead) is non-linear (purple lead is actually linear O/P)...unless you go into the software and set it (pin2) to output a linear function. In 2010 versions of the ZT-2, pin2 automatically defaults to linear O/P.
    Regarding your Dynojet; talk to the manufacturer to confirm the upper/lower range is indeed similar to Zeitronix/Bosch O2 sensor (9.6 lower limit/19.6 upper limit). If you do require a cable and you think the cost is prohibitive, I'll fabricate one for you at double that...just kidding :^)
  5. #65
    HeavyHook's Avatar
    Apr 2009
    You know buddy....it's not always about cost. Most times, it is what it is. No getting around it. Sometimes I don't wanna wait 10 days to 3 weeks to get something from the US.
  6. #66
    Hemissary's Avatar
    Calgary, Alberta
    Not my intent to imply; however as you know there is sh!t that should cost close to sh!t...but it does not.
    It's somewhat(!) higher in price...for no good reason.
  7. #67
    monty1269's Avatar
    monty1269 is offline vajazzle it!....;)
    Aug 2005
    Pompano Beach, Florida
    So I can find this again...
    Hemi Registry 0436 6.1 block - CTP Dual intake - Modern Muscle ported intake manifold - Indy Heads - PWR cam - FTI converter - TTI Longtube(catless) - 3.06 gears - 17 X 8.5 Borbet TS w/ 275/40 Hoosiers - Diablo tuned!! Billet Tech Goodies EVERYWHERE. ALL Parts supplied by LXF vendors: Afterhours Mopar Performance, SpeedRated, PWR, Modern Muscle, Picklefork...and LXForum members. Installed by: Afterhours Mopar Performance
  8. #68
    NYC
    Quote Originally Posted by Thirsty4907 View Post
    mines not working i got the second plug that you suggested and it has a red a black and a second black thicker what do i do with that wire also i have the ZT-3 only has red, white black and purple wire
    but when i do as said it just sits on 9.5 and the gauge reads 9.5/9.5 the whole time
    x2. Same question here with ZT-3
    FOR SALE: 2006 Dodge Charger RT - 6.1 motor, Novi 1200 blower, Treadstone A/A FMIC, 392 fuel pump + KB BAP, Siemens 70# injectors, 190* tstat, 3.06 rear, Diablo Trinity, Tuned by Josh @ HHP, catless mids, Full Brembo setup, SRT steering & electronics, KWV2 suspension, Hotchkis sways, BWoody endlinks, SPC/Eibach UCAs, SRT fascia & spoiler, Trufiber SRT hood, MSRT wheels, 6000k HID lows/fogs, LED headlamps, SRT seats, MyGIG, 1ST COMPLETE '06 to '08 INTERIOR CONVERSION, ... & a bunch of other sh!t I cant remember!
