Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
  1. #31
    liljoejoe54's Avatar
    liljoejoe54 is offline LX Padiwan
    Sep 2007
    Chicago
    Ok so my '06 cluster does not have the 0-60 timer but I know the '07s do. So you are saying that I can buy an '07 cluster off of you that is programed with the 0-60 timer and have it altered so it will have my VIN and mileage in it as well? How would I go about doing this, just send you my cluster?
  2. #32
    Redfox0099's Avatar
    San Antonio, Tx
    In theory (Theory) we will have an exchange program setup.
    1. You order a custom cluster overlay for your car, it will have a 180 MPH speedo and custom artwork done.
    2. We program a "core" cluster with your VIN and mileage and send it to you.
    3. You receive it and plug it in and you are done, you then send you cluster in as a "core".... if everything checks out with your cluster then you are done... you have a custom cluster overlay with a 180 MPH speedo and a 0-60 timer...
    In Theory as of right now... still trying to see if there are any pitfalls.
  3. #33
    Redfox0099's Avatar
    San Antonio, Tx
    Went and played with it and there are going to be some growing pains... as 65 Standard mentioned the '07 Cluster did not allow me to open my rear hatch but putting my '06 cluster back in it did.
    Also some issues with copying the 0-60 timer and I am working on resolving it... patience please.
    I need to borrow someone car locally who doesn't have an SRT and install the 140 MPH speedo cluster the 180 mph cluster file was copied to to see if the calibration works correctly.
  4. #34
    Sep 2007
    Chicago
    Quote Originally Posted by Redfox0099 View Post
    Sounds like a good plan to me. I will be patiently waiting for testing to be done.
  5. #35
    cnhman2008's Avatar
    cnhman2008 is offline America F@$k Yeah!!!!!!!!
    Jul 2009
    lancaster pa
  6. #36
    65standard's Avatar
    65standard is offline Programmer/Fabricator
    Dec 2008
    Chicagoland
    Went and played with it and there are going to be some growing pains... as 65 Standard mentioned the '07 Cluster did not allow me to open my rear hatch but putting my '06 cluster back in it did....
    nathan, the problem is that you used a cloned charger cluster in a magnum, and not the 2007 in a 2006. everyone thinks the charger and magnum cluster are the same, but they are not. the good news is that you successfully cloned it.
    if you clone a 2007 magnum srt cluster and use that in your 2006, your rear gate will function normally. however the cruise control changed almost every year and you may have another issue with that.
    i am using an '07 superBee cluster in my '06 magnum R/T. i solved the issues with the rear gate and cruise control. the rear gate will work with a stock charger dash button. the ratman mod dash button will not work, but a stock button will. the rear handle can be modified by removing the resistor built into it. then the outside handle will work again. one plus is that the key FOB's 4th button will pop the gate remotely. the cruise was fixed by changing to an '07 stalk.
    i bet you can change my old '06 magnum R/T cluster into an '09 SRT challenger cluster for me.
    Tony
  7. #37
    RobAGD's Avatar
    Reston, Va
    Hey Tony - how did the cruise stalk change from the 06 to 07 that it needed to be changed ?
    I realy wanted to do a 07 SRT Charger cluster to get the 4th button and the kicker button to work, how much work is it to remove the resistor in the gate button ? Did you take pics as you did the work ?
    -R
  8. #38
    65standard's Avatar
    Dec 2008
    Chicagoland
    Hey Tony - how did the cruise stalk change from the 06 to 07 that it needed to be changed ? at a glance, it looked the same, but it was different. like the rotation direction or something like that changed. just look at your cruise stalk and then look at an '07 stalk and see what i mean. of course, the '08 is completely different and on the other side.
    -R
    the resistor is burried under the plastic. i had to dig away at the plastic until i found the resistor. i don't remember which side of the switch had it. i did have a thread with pictures showing everything, but it was deleted along with all of my old threads. i ended up giving the modified switch to a member here when i shaved the gate.
  9. #39
    Redfox0099's Avatar
    San Antonio, Tx
    You put a 180 mph speedo into a Car that had a 160.... When you installed it did It read like it had. 180 speedo or was it still trying to show you like you had the 160 in there?
    Posted via LXFMobile
  10. #40
    skippytrailer's Avatar
    skippytrailer is offline Supporting Vendor
    Nov 2006
    Mesa, Az
    Nathan, I hope that cluster is helping you out, just remember that when I want a custom one for the Mango someday
    2006 GoMango Daytona 2524-Sidewinder Cam- Borla-20" staggered Viper's -Diablo Predator- Painted Tails-SRT8 Suspension-AE Carbon CF CAI
    5% Tint & some airbrushed stuff
    Dinosaurs went extinct because of the Chuck Norrisaurus
  11. #41
    Redfox0099's Avatar
    San Antonio, Tx
    Go to my vendor section and fill out an order It's so Easy
  12. #42
    65standard's Avatar
    Dec 2008
    Chicagoland
    the 180 speedometer is accurate in my R/T
  13. #43
    BDA1855's Avatar
    BDA1855 is offline Ultra Heavyweight "Fatman" Race Team
    Nov 2008
    Riverside, CA
    I would love a 2007 SRT EVIC in my 2006... but i dont want to lose the rear hatch pop or the cruise control...
    how do i do this? do i need to find a 2007 SRT cluster?
    2006 INFERNO RED MSRT8 - SOLD-
    2005 FORD P71 Crown Vic
    DREAMING OF A NEW MOPAR
  14. #44
    billster's Avatar
    billster is offline LX Padiwan
    Feb 2009
    Nashville
    Just checking to see if you had success trying this out on a non SRT...
    thanks...
  15. #45
    RMassa187 is offline LX Padiwan
    Boston, MA
