Originally Posted by
CoolVanilla
Oh maybe it is Lou. You're talking to a total noob on this stuff. Please forgive the verbiage, but here's what has me concerned:
1) the tube that holds the cartridges (under the barrel) will rotate maybe 10-15 degrees either way.
2) the pump action is very tight/stiff.
3) sometimes I have to overextend the pump action to get the slider to unjam. If I go the normal stroke, it works most of the time, but once in a while it will lock up on the way back. I have to go forward again, beyond the normal stroke to free whatever up, to then be able to pull it all the way back.
4) is it "safe" ? I dunno.
You tell me... am I being a goober about this? Should I just get out there and use the sucker? I plan to hit the local trap/skeet/clay sports park fairly regularly...
