Has anyone her installed a underdrive pulley? I am thinking about getting one but only if one of you guys could help me install it. thanks
I eat through end links like candy bars!
I didn`t install mine - had FRI do it. But reading up on it found out a couple little tidbits...
Let the car set for about 5 hours to let the crank become totally cool to make sure the metal is totally contracted
Boil the pulley for about 15 minutes to expand the crank housing
"DETONATOR"
Sidewinder numbers
1/8 8.45@82.90
1/4 13.14@107
Certified AAC Houston Installer
thanks. how much did they charge you?
im saving mine that I got already for my cam install so it will be free b/c they got to put it al back on when there done right..so why not save money!!
Magnum Rt
Performance Mods: Slp Loudmouth I - Diablosport w/91 tune - 180 Tstat - AFE Stage 2 - Dynatech LTs - MTCM - sparrow cam
-Other Cars
05 Ram 1500 - gone
92 AWD Plymouth Laser - gt30r 20psi Low boost - gone
91 Dodge Stealth rt TT - gone
05 Dodge Magnum - Still Grining
86 Foxbody Mustang - 331 stroker !
MHP seemed to put mine from PPP on when the car was cool pretty easily this weekend, block was also pulled so it wasn't too much of a problem. It fit fine, just needed the new bolt and belt too... no worries. Haven't seen any dimming yet my battery reads at an average of 14 volts, but that's also without a/c on.
Lopey: 6.1L N/A Modified / 3700lbs 473rwhp/439tq ~ Quickest ET : 11.152/117.5mph, 1/8 - 7.0/99.56, 1/4 Trap - 126.15mph <~ Sold
R.I.P. Lou1355
R.I.P. Lou1355
Where is everyone getting the puller needed to remove the stock pulley???
07 Magnum R/T AWD
Mods: Diablo,C&L Intake,180 T-Stat, Dual Magnaflows, Moe's Ported TB, PB Underdrive Pulley, TruFiber SRT Hood, custom gauge cluster, HF cats w/ E-cutous. FRI Sidewinder and JBA Shorties awaiting install!!!
