Looking at my latest attempt at the strip and wow......maybe tomorrow I will learn how to launch this pig.......
Here is one of the runs, the run begins at 25 seconds into it
http://s182.photobucket.com/albums/x...2-12-13-01.mp4
If I can learn to relax and 60' this pig what do you suppose a good ballpark would be for the car
60' 2.268 330' 6.028 660' 8.992 990' 11.445 1320' 13.644 MPH 106.62
60' 2.505 330' 6.253 660' 9.217 990' 11.672 1320' 13.874 MPH 105.77
60' 2.444 330' 6.175 660' 9.137 990' 11.590 1320' 13.793 MPH 105.49
60' 2.425 330' 6.379 660' 9.395 990' 11.872 1320' 14.085 MPH 105.91
So I split the times 330-60....660-330...990 by 660 and 1320 by 990...
I can see traction in the first 330 is an issue where I really need to pay attention to the car.
The times from 660 to the 1320 are so close and very consistent and thats great
Based on the above anyone got an idea on what I should be running if I can pull a 60' of 1.7 to 1.9? Tomorrow I plan on starting the day with the Nitto drag radials 275/40/20's at 17psi and will have a compressed air tank with me....I am planning to adjust up from there, or should I be starting high and adjusting the pressure down?
So far I have learned alot about the car and racing. Even though my times are ridiculous for my mods I am pretty happy knowing I still should tickle the 12's if I can launch the car.
JBA shorties catless mids and SLP Loud Mouth I, K/N typhoon, powerbond undrive pulley, 170 tstat, mopar TCM, blue tops, R1 crossdrilled/slotted rotors, HAWK Pads, SRT MAX on 112, CNC Inertia Heads milled, 3000 Edge converter 3.91 Getrag 09 axles installed!#157 of 1400
157 0f 1400
http://s182.beta.photobucket.com/use...20563452620283
I would start the PSI at 25lbs and work down from there....17lbs might work but you might be a little unstable at speed....you have a low/mid 12s car....just need to get it launched...
2013 CHALLENGER SRT8 AUTO IN BLACK
LMI TRUE CAI
MOPAR LOWERING SPRINGS
BLASTIN BOBS AXLE BACK W/ RESONATORS
MAGNAFLOW MID W/ HIGH FLOW CATS
3.73 GETRAG LSD
EDGE 3400 STALL CONVERTER
SPEEDLOGIX REAR SEAT DELETE
......MORE TO COME....
Thanks Larry!!
You are everywhere!!
High 12s with a good 60ft.just not enough MPH to bring it into the low 12s
Sent from my DROID RAZR using Tapatalk 2
*New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
Damn high 12's seems to be the take.......looks like I should have spent my money a little more wiser!!!
So any suggestions on how to get into the low 12's? I running milled heads....I guess time to stroke and go big.....
Well I average a 2.0 60ft on my car with Srt Max and all bolt on's and I'm running 12.7 all day long.saw a 1.898 one time and went 12.523..all traps are 111 112
Dave that 3.91 rear may be hurting you.....
I agree the 3.91's might be an issue!
skipping the track in the am....will run on the 7th of july. I have a few tings to think about..........
What size tires are you running?
Opps....missed that in ur post.
Tagman
It's TORRED or NOred!
17 lbs is to low, I'd start 1t 20-22lbs, then go down if you spin. I ran 17 psi last trip and did not hav fiull contact ara. check your contact area, when You see a line onthe outside edge that is differnt colored than the rest your PSI is to low. you definatly will see 12.8x or better if you can launch, so maybe pracitice that somewhere safe. I generaly just load the TC up enough to feel the car try to pull forward, then go to WOT while lifting off of the brake ..at the third amber light. I think your car is capable of a 1.7-1.85 60 foot. go or it!
08 R/T LMI TRUE CAI, eagle intake. Modern Muscle Perferformance Group 85mm Ported TB, CAM, and ported eagle heads. SLP underdrive pulley. 6.1 timing set,and lifters, PSI springs custom pushrods, cometic head gaskets, 11:1 comp. American Racing 1 3/4" long tube headers , highflow cats. SLP SRT8 3" catback with Magnaflow 3" mufflers, 4" tips., catch can 170 stat. Builder Bill rebuilt tranny, stage 2 valve body, 3500 stall TC, AFI flexplate. Getrag 3.06. MTCM. BC Coilovers. Pistol grip shifter. Tuning Johan.
NEW04/6/13: 11.847 @ 118 mph .
That's a lot of gear but with some GOOD drag radials/slicks I'd think you could still hook it and go fast. Maybe some Hoosier 28x10x17 slicks?
It may not be set up ideal for the strip but I bet that car is fun to drive!
2010 Charger Police Package
12.69 at 106mph - completely stock 5.7 motor - 2093 DA - 4300lbs with driver
Diablo InTune - 180* Jet Stat - 3.06 open diff - FTI 3200 Converter - Hoosier DR's - K&N drop-in - BT catch can
