How are yall tightening and Torquing the front spacers with the rotor spinning freely... I made my own solution but wanted to see what others had done.
What torque setting are yall using?
I always have someone hold the brake while I torque them down. I torque them to 100 ft-lbs.
RIP Lou
Only way to do it is to have someone hold the brake or use an impact gun.
Originally Posted by JusticePete
My Pedders ExperienceOriginally Posted by JusticePete
Yeah powerwagon does something different as well.
Not sure exactly....
RIP nhDave - Never forgotten, my friend
______________________________________
11.59 N/A and 11.19 on 100 shot.
392 with Frank Racing heads and cam.
Dominator Converter.
Install by HEMI31.(BNFY Performance)Tuned by LAFRAD.
The spacer nut's from adaptitUSA.com are wedge nut's, don't need a lot of torque. I have to use a cheap 13/16 socket because the good ones get gauled in the hole.
Cut some wood to length and brace it off the driver's seat to the brake pedal, and move your electric seat forward to keep it held down. Notch the end of the wood so it can't slip off.
Like an old hockey stick. Or baseball bat if you're not in to hockey. (Like WTF who isn't in to hockey?)
2006 Magnum SRT8 - 11.85@117
I did exactly this using my aluminum racing jack handle. Tilt the seatback forward as far as possible to get the angle right so the handle doesn't just slip up the seat.
Then put the handle on the brake pedal and move the seat forward until the brakes hold.
Then tighten the brakes. Works well when there's no one else around to help you.
impact gun will get the job done every time with no wheel spin. 36v FTW!
Current mods: Hi-Flows, 180. POC, PS Cooler, Trans Cooler, SS Brake Lines, Ti Backing Plates.
Pedders Track II Extreme, Wavetrac, MOPAR 6.1 TCM, Mopar trailer hitch and harness.
Use a bar between two opposite studs, and the torque wrench on an inset nut. Position the torque wrench so you can bring the two levers together until the proper torque is achieved. Easy. You're not putting enough sideload on the studs to hurt them, and the bar can be most anything you already carry.
How about just sticking a screwdriver in one of the vents of the rotor and let it rest against the caliper while your tightening them?
Eddie... 2006 Dodge Magnum SRT8... Yeah Baby!!! N.Y.H.H.
Air Hammer CAI, American Racing Headers, SLP Powerflo Cat Back, SLP pulley, 85mm TB, Paramount Perf. 3400 Stall T/C and Driveshaft, BT catchcan, Getrag, Blue top AMG solenoids, AMG shifter paddles, Diablo Trinity, 12k HID's...
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
