Results 1 to 8 of 8
    budoboy's Avatar
    budoboy is offline LX Newbie
    Feb 2006
    Limp mode is hurting my burnout mojo!! Please help!
    I went from a taller wheel/drag radial combo back to a smaller diameter combo and now once again have a hard time not hitting limp mode.
    I tried starting in second gear but the first time I only got to about 4500 before slowing and the second time when I gave it more gas it hit limp mode again.
    My first burnout in 1st gear was the best but as soon as I let off the brakes it seems the rpms shoot up (even when I'm off the gas) and BANG - limp mode.
    My shift points are at 6400 and my rev limiter is either at 6400 or 6500. I could try dropping my rev limiter but don't want to hit the limiter just before shifting.
    Any suggestions? Hitting limp mode every time or doing a half-assed burnout is really affecting my mojo and my confidence in launching the car.
    Also sometimes after re-starting the car is in some kind of safe mode and feels like timing is being pulled heavily for the first half of the quarter mile. It only does this sometimes though
    *Winner of New Hemi Challenge Class at Mopars at the Strip (Las Vegas) 2010
    *Winner of 6.1L N/A Class and King of the Hill at Atco Modern Mopar Shootout 2010
    torRed #1169's Avatar
    torRed #1169 is offline Who has the winning lottery numbers ???
    Nov 2006
    15 minutes from Englishtown
    Raise your rev limiter.
    RIP nhDave - Never forgotten, my friend
    ______________________________________
    11.59 N/A and 11.19 on 100 shot.
    392 with Frank Racing heads and cam.
    Dominator Converter.
    Install by HEMI31.(BNFY Performance)
    Tuned by LAFRAD.
    budoboy's Avatar
    Feb 2006
    Quote Originally Posted by torRed #1169 View Post
    I had it about as high as it could go (last time I had short rims/tires) and it would still do it. I need to hit the rev limiter to keep from going into limp mode but it flashes the RPMs too fast. With the bigger tires it would hit 6500 rpm over and over during the burnout and just keep bouncing off the limiter which was no problem.
    charginscott's Avatar
    charginscott is offline LIVING A DREAM
    Alvin, Texas
    Jeff raise the rev limiter up to about 6800 rpm. That is what my 5.7 is at and it shifts at 6400
    "DETONATOR"
    Sidewinder numbers
    1/8 8.45@82.90
    1/4 13.14@107
    Certified AAC Houston Installer
    Guest Guest
    You don't need to redline to do a burnout.
    If you're unable to manage this, simply put the car into autostick mode, and essentially the second you floor the gas, shift up to 2nd gear. It'll pause long enough to climb high in the rpm range in 1st, then shift to 2nd just in time before you redline it.
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    I just put the car in 2nd using autostick and then do my burnout. If the RPMs get too high I let off a bit, I try to hold it around 4000-5000. I've hit limp mode a few times because I was watching the mirrors to see if both tires were spinning and wasn't paying attention to the RPM. I shouldn't have to worry about that now.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    budoboy's Avatar
    Feb 2006
    Thanks guys! Sounds like there is no magic pill I was hoping for. I'll play around with the rev limiter some more (lower and higher). I need to set up a burnout box in my driveway for practice. I hope the neighbors don't mind :-)
    PPP-Justin is offline LX Padiwan
    May 2009
    everytime we raise the shift points, we go into limp mode during the burnout at the 1-2 shift. Just keep it in first gear for the burnout, drag radials do not need to get that hot.
    E-mail at Sales@powerported.com for any info on our products
