Results 1 to 15 of 15
    deleted
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by 65standard View Post
    without changing parts, what can i do to improve my 60' time? with perfect traction, i get 1.90 to 1.92 every time. i always leave at idle and mash the pedal. i tried to brake torque it once, but i pushed the car past the staging lights. i just can't hold it back with a stock converter.
    what is the best 60' time for a 5.7 magnum with a stock converter? mine is 1.90 with and without drag radials. drag radials have not help my 60' time at all.
    With the stock converter I think brake torqueing to around 1500 works out pretty good.
    I think 1.90 is pretty good for a stock converter, especially if it is consistant
    Video
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    1.7's are not very likely with a stock converter. The best I was able to manage with the DR's was low 1.8's. The Pro Torque dropped 60' by aprox .1 on average.
    Stupid Nasty.... 9.59 @ 148
    PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    I have gotten 1.8x with street tires and a stock converter. I bought a 2800 stall but...
    C.
    Silver 06 CSRT-8
    InferAl's Avatar
    Nov 2006
    NE Ohio
    If you stall the stock converter to high it will actually hurt you 60 ft times
    Video
    MikeEast's Avatar
    Ducktown, Georgia
    I've not ever gotten below 2.0x for 60' times - how the heck?
    Mike
    HoonLo's Avatar
    HoonLo is offline LX NINJA
    The netherworld
    Nor I, and I probably have like fifty attempts!!
    Much you have to learn....Teach you I will!
    12.93 @ 106 so far....
    You may not be interested in HoonLo but HoonLo is interested in you!
    mcshocks is offline Powered by GTP headmasters
    Minnesota
    Brake torquing to 1500 rpm worked well for me, consistent 2.0 60's on my last track outing and snatched a 1.9X once, only been to the track 2 times with this car so far. The 1.9 60' was with no wheel spin at all and babying it out of the hole for the first 10-15' all the 2.0's were with light wheel spin (never got a 1/4 mile slip for the 1.9 60' just a 1/8 mile as it was brackets later that night done on 1/8 mile times, but the numbers showed better across the board, I thought babying it might hurt my trap speeds but it didn't, makes me wonder what the pcm is doing with wheel spin?).
    65standard, let me know if you wanna hit up 41 next spring, I go out your way quite often.
    1/4 mile: 12.32 @ 111.12 MPH on a 1.72 sixty foot
    Fast56k's Avatar
    Mar 2006
    and what was your launch technique on that? remember, i have a 4522lbs magnum 5.7. (even heavier now with the 20" boyds i am racing with)
    I load it up to 2k and gently increase at launch for about 1/2 second until I am sure momentum will keep the tires from spinning, and then I put the hammer down.
    C.
    Silver 06 CSRT-8
    TPBNANA-1606's Avatar
    TPBNANA-1606 is offline I'm HAMMERED 24-7/365
    NJ
    Add me to the "I haven't broke 2.0 60' either",i think its pretty good if ya ask me.
    Thanks HAZMAN..........
    all_bran is offline LX Padiwan
    Dec 2006
    Royal Oak, MI
    me too. I was at the track today and couldn't pull better than a 2.11 with the SRT8 Eagle F1 supercar tires (255 wide). Now, it was 48 degrees, but still. Even if it was 80 degrees outside, I still probably wouldn't have broken below 2.00... If you're getting a 1.9x with a stock set up and the R/T 235 or 245 tires... shut up and be happy LOL! Remember, every 0.1s in your 60' time makes a difference of 0.2s in the 1/4 mile. Almost an exact science...
    Hotdog's Avatar
    Hotdog is offline LX Collectable Owner
    Aug 2007
    Round Lake Beach, IL
    Yesterday in 10 attempts the best I could do with a stock Magnum R/T was - Best 60' = 2.183
    I must be doing something wrong??
    Hammer CAI
    Corsa Cat-Back
    176* Thermostat,
    Diablo Predator 93 CAI Tune
    No-ESP
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    I can't break 2 for the life of me. Mostly due to traction. I might need to strap on some DRs just one time.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    I was in Pittsburgh Tony, home now, got your messages!
    Nice times today, and GREAT MPH's
    Don
    mikespy's Avatar
    mikespy is offline Fastest N/A 5.7L Magnum around!!! SOLD!
    Houston
    i was hoping you would show. the DA was -197'. it doesn't get any better than that around these parts.
    I think you have one of the best 60fts with the stock verter i've seen....
    Wait till you get a converter tho... your times are gonna drop even more Tony!! AWESOME mph Bro!!
    2010 SRT8 Challenger...
    MODS: Magnaflow Competition exhaust, Roto-Fab CAI.....
