Results 1 to 15 of 20
    Carfinish's Avatar
    Carfinish is offline Capeeesh!?
    Nov 2005
    White Plains NY
    How TO: Trophy Football Setup in Sig
    Ok so I'm seeing that some members have just a little problem on how to display that .gif file they worked so hard to get..... so here is the crazy tutorial.
    if you do not use the image I post for you and try to place it in your sig another way the ball could shrink...and who the heck wants shrunken balls
    (for Mozilla browser see post #7)
    First you need to go to the image posted for you in the repsective thread ....see the one below....right click and hit copy
    Then you go to your Users Control Panel and follow the steps in the image below
    1- click on Edit sig
    2- find location in window you would like to set said image
    3- right click and select paste
    4- scroll down and click "save changes"
    if you do not like the ball location ....go ahead and play with your balls for proper placement
    now, most of you knew this but if you are trying to host the image on a different photo site, you stand the risk of shrunken ball syndrome.
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, DRs & skinnies
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Thanks for the tutorial, Stell.....and the chuckle.
    John Y
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    Whew.... Thanks for clearing that up Stell..
    12.645@108.18
    TTMR's Avatar
    TTMR is offline Will wrench for AvGas
    Cincinnati, Ohio
    So THAT'S what I did wrong!
    Thanks Stell
    He is just fast everywhere"
    - FlyByU
    Carfinish's Avatar
    Nov 2005
    White Plains NY
    it was time, boys.... it was time ....
    RIP
    torRed #1169's Avatar
    torRed #1169 is online now Who has the winning lottery numbers ???
    Nov 2006
    15 minutes from Englishtown
    That is great Stell.
    You might want to mention that it's little different if you use a different browser.
    Your instructions are for Internet Explorer. Who still uses that??? Crazy!!!
    Mozilla Firefox is better and doesn't quite work the same way.
    RIP nhDave - Never forgotten, my friend
    ______________________________________
    11.59 N/A and 11.19 on 100 shot.
    392 with Frank Racing heads and cam.
    Dominator Converter.
    Install by HEMI31.(BNFY Performance)
    Tuned by LAFRAD.
    Carfinish's Avatar
    Nov 2005
    White Plains NY
    hey you think this is a university or something....for you Mozillas.... you will want to right click on the image.....go to properties....highlight the URL (location) of the image (click left mouse button, hold, scroll and highlight).... right click & copy ...then go to edit sig per above and through step 2....then hit that little yellow icon with a mountain and you will insert image....will ask you for the URL, then right click and hit paste....click OK....and then step 4 above....repeat until balls are in proper location ....
    RIP
    Carfinish's Avatar
    Nov 2005
    White Plains NY
    This thread deserves a BUMP...some of you guys are displaying your shrunken balls...
    also...you should be using the image I post in the records threads...some of you guys copy them into your own account and does not show the clear background... fix your balls...
    RIP
    lou1355's Avatar
    lou1355 is offline Hoosier Daddy - Finder of Weak Links
    May 2006
    South Florida
    Dang, Stell...when it comes to all things balls you are the Level II Expert!
    Carfinish's Avatar
    Nov 2005
    White Plains NY
    Quote Originally Posted by lou1355 View Post
    well...I'm thinking of a comeback... but anything I say will get me in trouble...lmao, so I'll just say thanks Lou
    RIP
    lou1355's Avatar
    May 2006
    South Florida
    Quote Originally Posted by Carfinish View Post
    joelvan's Avatar
    joelvan is online now Police car Racer
    Jul 2009
    Cornelia Georgia
    Hey it works now.
    thanks alot.
    Joel
    Jack SickSRT's Avatar
    Jack SickSRT is offline LX Guru
    Sep 2009
    Va. Beach Va.
    Very helpful information! Now the wife wants to know if this will work for me without calling the doctor after 4 hours? After all ball placement is everything in a healthy marriage; Isn't it?
    Best ET KB & N02 - 9.800 Best ET KB Only - 9.91
    1st 6.1 in the 9's "Jack the Snake"
    ylwnana's Avatar
    ylwnana is offline LX Padiwan
    Jul 2007
    studio city, ca.
    thanks!!
    06 rt, SMS supercharger with custom CRANK THIS PERFORMANCE cai, ARRINGTON 90mm, srt exhaust, corsa cat back, SMS big brakes, quaife ltd, kwv2, hotchkis sways, eibach front upper A arms, custom front strut brace and sub frame brace by STACK, R.E.M rear strut brace & matrix sub frame brace, TRUFIBER carbon hood.
    Charger4Life's Avatar
    Charger4Life is offline I'd rather be racing.................
    Greenville, South Carolina
    Hope to be using this thread in a few weeks......
    Frank's SPARROW cam, Indy Maxx heads, LMI Fender Pull Intake, Edge High Stall Converter, Full SRT exhaust, 399 rwhp, 407 ft.*lbs.
    5.7 N/A 11 second club Best times to date:
    1/8 mile E.T. 7.42 @ 93.53 mph.
    1/4 mile E.T. 11.696 @ 114.24 mph.
    1.60 60 ft. best
