Results 1 to 7 of 7
    TTMR's Avatar
    TTMR is offline Will wrench for AvGas
    Cincinnati, Ohio
    Question Help a Noob out?
    Ok so Saturday I'm plaining to make my first trip out to the drag strip. I know that I'm not the best thing to happen to drag racing since the wheel so I'll listen gratefully to any advice given, no mater how basic. (Yes I know, skinny petal to the floor) I'm an AWD and a V6 at that so traction shouldn't be any issue so I would imagine that this will be more or less a point and shoot kinda thing. Any SXT guys out there have any input for launching? The temperature here is supposed to be in the 20's so the DA should be below sealevel which makes me optimistic for some good ET's,well, for a V6 any way!
    Thanks guys!
    He is just fast everywhere"
    - FlyByU
    Deuces is offline Predator Installed!!!
    Roselle, IL
    Leave on the last yellow and gun it.
    '06 Stone White SE - Predator 93 Octane Tune Installed! ~~~ SOLD ~~~
    Midnightsun300c's Avatar
    Midnightsun300c is online now Large Carbon Footprint
    Eagle River, Alaska
    Quote Originally Posted by TTMR View Post
    Thanks guys!
    -Talk to as many guys at the track as you can and ask as many question as you can think of. Most guys will go out of their way to help.
    -Turn your engine off if you need to wait a long time in the staging lanes.
    -Drive around the water,not through it, and wait for the other car to smoke the tires. You only want to go through the water if your going to smoke your tires, and you are not.
    -Pull up to the tree with the other car and wait at the stage light for your opponent to turn on his stage light too. This is etiquette.
    -Inch forward until you just break your start light for a "shallow stage". This is so you get maximum momentum when you launch.
    -For your first few tries leave after the second yellow has lit but before the third. Your reaction time will be slow at first and with your AWD V6 you won't set any records in that first foot leaving the second beam.
    -Don't worry if you "red light" just keep the pedal to the metal. You can learn from your time slips just the same.
    -If possible keep making successive runs even if your engine is hot and your ETs aren't their best. If you can do a number of launches in quick succession it will really help your reaction time and hone cutting a great light. Aim for .05 reaction time. Guys that practice a lot can cut .01-.02 lights all day when using a full tree.
    Have a great time. I'm sure you'll get hooked.
    Honorary First Member – LX AWD – 11 Second Club
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    Eagle River, Alaska
    So how did you do?
    TTMR...Did you make it to the track and if so how did it go?
    TTMR's Avatar
    Cincinnati, Ohio
    Nope the track was closed for weather, a nice snow/ice storm came though on Friday and made a mess of things, I'll try again this weekend.
    - FlyByU
    TTMR's Avatar
    Cincinnati, Ohio
    wish me luck, I'm heading out now.
    - FlyByU
