So there is a good chance i will head to mission raceways this friday and post some times for my car what do you think with my current mod list i can run with slicks??
The winner will get a shiny nickel!!!!! ha ha!
11.15@ 118.65![]()
Ken & Laurie
2006 TB Daytona #1458 (His) 13.82 102.49
2007 Plum Crazy #765 (Hers)
I think with good air and traction i would be high 10's no?
its not your first time out is it? with a build like that id hope not. the 11.1 does sound pretty good. there are very few 10 second cars right now. even less on the west coast and in june that makes it even harder. good luck though, be safe and have fun. remember 11.5 you need a roll bar at most tracks, and slicks (not drag radials) need a drive shaft loop.
Hmm! Who tuned it? How much boost you running? Tell me about the Nitto Slicks? You running front skinnies?
Jim "Meister" Edwards
RIP "SLICK"
Where are you going to find good air this time of year and how much seat time do you have with that set-up? I'm guessing 11.18
Personal Best: coming soon!!
Currently on 7psi of boost was built and shipped out here and had mopac do the install and they cmr tuned it.
Car needs to be retuned im starting to find flaws in it now and a friend of mine suggested i try bob at svs? not running skinnes yet im going to look at a set in the next day or so. what would you like to know about the nittos?
10.83
11.6 @ 122 or so.
Current mods: Hi-Flows, 180. POC, PS Cooler, Trans Cooler, SS Brake Lines, Ti Backing Plates.
Pedders Track II Extreme, Wavetrac, MOPAR 6.1 TCM, Mopar trailer hitch and harness.
11.5@125...... first time out will be a learning experience.
BFNY PERFORMANCE
RIP My Friend
Mouth watering combo! But it's probably going to blow the tire's away, First run 12.00@122.5 (I hope you make me eat this post)
I'm thinking you ment the nitto 555r's drag radial's? If so those are a long way from slick's, Cook'em good! No slick's on web site yet, But I see guy's asking about them performance wise in other post's! If their real slick's I guess I'll be having a post for lunch this week.![]()
those nittos are going to really be hurting you.
id consider stepping up to some hoosiers on 17's.
after that it will take a lot of time dialing it in to really run good.
10's are absolutely do-able, but it will take practice.
what is your race weight?
p.s.
if you can get that car to bob at SVS, he will get you nailed down perfect on the tune, hes good stuff
Depends on what track you are racing at. But first time out mid 11s should be a good goal for you.
Originally Posted by JusticePete
My Pedders ExperienceOriginally Posted by JusticePete
RIP "SLICK"
