Results 1 to 4 of 4
Thread: 60ft
    B/A Charger R/T is offline LX Newbie
    Feb 2009
    NWI/Chicago Land
    60ft
    Hello i have mickey thompsons on the rear and still spun at the track my 60ft was very bad i droped the pressure in the tires to 19pounds and still didnt hook any ideas
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    I had the same trouble with MT 315's until I actually raised the pressure enough that I could freely spin them in the burnout box - if you don't heat them up well, they just don't catch.
    In my case, I tried them all the way from 17psi up to 28, and I couldn't reliably spin them free when doing a burnout. I finally tried them at 34psi, and they worked great! Spun them free, heated them up, and then once I was staged and the light turned, I hit it hard at they stuck and went.
    So unless you're sure you're getting a good burnout on both of them, I'd suggest trying a little more pressure to see if that helps.
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    What kind of mods do you have? Make sure you get them both heated up evenly and they should stick.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    I ran the Mickey Thompsons religiously for a while. I had best results running them between 18 and 22 psi. Best 60' was high 1.6's with low 1.7's being the norm. Heating them up evenly was certainly the key. Seems that getting them spinning in the water was the best way to start out.
    Good luck,
    Chris
    Stupid Nasty.... 9.59 @ 148
    PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
