13.7 sec @ 102.52mph
Finally got some good runs in today using the ACES IV fuel catalyst.
My best run was a 13.7 @ 102.52 (car weighs 4420 w/driver)
Previous run was 13.9 @ 103.49.
I had 1/4 tank of 89 Octane combined with ACES IV. Weather was 46-48 degrees, 24lbs of air pressure on OEM tires.
Had only 1/4 tank of fuel and temps were 45-48 degrees. I was also using the ACES IV too which gave me a 97/98 octane rating with the 89 octane of fuel from the pumps.
1st run
R/T----.333
60ft--- 2.11
330----5.959
1/8----9.057
1000---11.713
1/4----13.943
MPH---101.19
2nd run
R/T---.039
60ft---2.181
330---5.994
1/8---9.079
MPH--79.75
1000--11.725
1/4---13.932
MPH---103.49
The only thing I did different was take out my spare tire and spun my OEM tires more than the 2 previous runs. All runs had 24lbs of air pressure.
3rd run
R/T---.123
60---2.102
330---5.859
1/8---8.921
MPH---80.00
1000---11.564
1/4---13.777
MPH--102.52
When I use the HP calculator with a weight of 4420lbs and 13.7 sec.......it comes in at 408 flywheel hp and 340rwhp.
__________________
THE DETAILER www.spalisautodetailing.com
Mods--AIRHAMMER CAI, Borla 125's, 180 Stat, Catch Can, Predator w/91 Octane/CAI Tune, ACES IV, 7.5w-23w oil, 75-115W gear oil, Quantum Blue tranny fluid. Best to date 13.7sec @ 102.52mph
Right on!
Glad you had a good day. It's always a good day when your times get lower & lower...
12.939 @105.26 mph Hi-Flow Cats, JBA shorties, Reso Delete, C & L, MoPar TCM, TB, 3.06 gears, CMR Toon, Pro Torque 2800
- You may not post replies
- You may not edit your posts
Forum Rules
